> spring rates, which is good for sport use?
post Apr 28, 2007 - 3:50 AM
tufy
Joined Dec 3, '03
From Cyprus
before i ask my question i want to explain what spiring rate is..
Spring Rate is the amount of weight needed to compress a spring a certain . Springs are rated in LB/in (in metric system kg/mm), or specifically, how many pounds of weight are required to depress the spring by one inch.
Springs that have a low Spring Rate are soft, while springs that have a high Spring Rate are stiffer.
Question is, what spring rates does every one with coilover kit have. and are you happy? what is optimum spring rate for sport use. 10 kg/mm front and 8 kg/mm rear seem ok to me. wht do you think guys.?
This post has been edited by tufy: Apr 28, 2007 - 4:29 AM
- tufy   spring rates   Apr 28, 2007 - 3:50 AM
- - purplegt4   mine are 7 kg/mm front and 5 kg/mm rear these rat...   May 7, 2007 - 3:02 PM
|- - Kwanza26   QUOTE(purplegt4 @ May 7, 2007 - 8:02...   May 7, 2007 - 9:59 PM
- - playr158   He's running Tein coilovers   May 7, 2007 - 11:12 PM
- - malpaso   tanabe using spring rate 3.5/3.0 kg/mm as almost s...   May 8, 2007 - 12:35 AM
- - tufy   thanks for the info guys. i think 7kg/5kg is ok   May 8, 2007 - 1:21 AM
Lo-Fi Version Time is now: July 29th, 2026 - 2:31 AM
