Apr 28, 2007 - 12:13 PM
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
Hi guys,
I thought I had solved my first start problems last fall when I had the my swap done, by cleaning out the Idle control valve. But it has return with the warm weather. Here is my problem: All winter, car starts fine with no problem at all. Now with the warm weather (above 65 degrees), when I first start the car it will start (at a low rpm 500) and slowly within a matter of 3secs stall. But if I start it up right away, it will start and run fine as if nothing is wrong. This seems to be happening with warm weather and the other thing is it ALWAYS ALWAYS starts fine on the second attempt, ALWAYS. I never have to start it more than twice. Also on first start ups when it is about to stall, if I lightly tap the gas pedal and let go, it will continue to start and run without stalling on me. I read the cold start problem thread and now I'm wondering if my problem is the CSI or the coolant tempt sensor or something related to fuel? I have cleaned out my throttle body and the Idle control valve but to no avail. Any help will be greatly appreciated. Thanks This post has been edited by malecrod: Apr 28, 2007 - 12:14 PM -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
malecrod Warm weather brings first start problem Apr 28, 2007 - 12:13 PM
toyotacrazy QUOTE(malecrod @ Apr 28, 2007 - 12:1... Apr 28, 2007 - 11:38 PM
malecrod Well, I cleaned out the IAC again last weekend. I... May 14, 2007 - 8:12 PM
lagos its the cold start time switch. i had the same pro... May 14, 2007 - 8:19 PM
malecrod QUOTE(lagos @ May 14, 2007 - 8:19 PM... May 14, 2007 - 9:07 PM
brianforster i have the opposite problem and have changed my CS... May 14, 2007 - 9:42 PM
malecrod I'm glad to announce that the starting problem... May 20, 2007 - 6:54 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 4:20 PM |
