Apr 29, 2007 - 8:26 PM
Enthusiast Joined Jan 31, '06 Currently Offline Reputation: 0 (0%) |
Ok, same buddy having different problems.
Whenever he is driving, and it gets up to a certain temperature (just over halfway on the gauge), the engine will just shut off, and will not restart until it cools down. But if you run the heater, it takes awhile before it shuts off. Any ideas? |
JaxMadine 3sgte cutting out. Apr 29, 2007 - 8:26 PM
CaliJeff Sounds like your engine is overheating. Apr 29, 2007 - 11:24 PM
toyotacrazy QUOTE(CaliJeff @ Apr 29, 2007 - 11:2... Apr 29, 2007 - 11:46 PM
Alan IS IT OVERHEATING? CHECK THE CODES!! Apr 30, 2007 - 4:25 AM
JaxMadine It is not overheating, there is no codes.
The Tem... Apr 30, 2007 - 5:01 PM
toyotacrazy QUOTE(JaxMadine @ Apr 30, 2007 - 5:0... Apr 30, 2007 - 5:21 PM
toyotacrazy QUOTE(toyotacrazy @ Apr 30, 2007 - 5... May 1, 2007 - 7:21 PM
lagos scan the ecu for codes. May 1, 2007 - 12:39 AM
Insanity-74 The temp needle should sit just under half way...i... May 1, 2007 - 5:25 AM
JaxMadine again, there are no codes! I checked! Enou... May 1, 2007 - 3:16 PM
JaxMadine The guy who put the engine in did the wiring. Some... May 4, 2007 - 7:16 AM
alltracman78 If your engine overheats, it will NOT just shut of... May 5, 2007 - 4:59 PM
toyotacrazy QUOTE(alltracman78 @ May 5, 2007 - 4... May 5, 2007 - 10:28 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 30th, 2026 - 2:36 PM |
