Apr 30, 2007 - 11:28 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
If i buy the cusco camber kit from japanparts.com, does anybody know if will make the camber perfect or slightly better?
-------------------- I'am Reinventing the SLow Lane.....
Apr 30, 2007 - 11:43 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
It will make your camber adjustable. You can give your car slightly negative camber or you can put it to no camber.
Apr 30, 2007 - 2:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I didn' thave much luck with them.. I had airbags and was of -4 and -3 degrees in the front.. after camber plates.. I went to -3 and -2.. so it wasn't very helpful..
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Apr 30, 2007 - 10:24 PM
So you were still pretty much eating your tires away huh?
May 1, 2007 - 8:44 PM
QUOTE(celica47 @ May 1, 2007 - 3:24 AM) [snapback]552708[/snapback] So you were still pretty much eating your tires away huh? yep.. inside of the tires were dead.. i was showing thread when I pulled one off for a show... scared me. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
May 7, 2007 - 2:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
i'm sure they will work fine if you lowered your car around 1-2 inches.
May 7, 2007 - 4:23 PM
i'm sure if they were in the hands of a professional they could achieve better than daniel's results...but also considering how low airbags go, it doesn't really compare to someone with coilovers or springs which won't achieve a drop that severe
This post has been edited by playr158: May 7, 2007 - 4:24 PM |
May 8, 2007 - 9:57 PM
QUOTE(playr158 @ May 7, 2007 - 9:23 PM) [snapback]555076[/snapback] i'm sure if they were in the hands of a professional they could achieve better than daniel's results... hey now -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
| Lo-Fi Version | Time is now: July 28th, 2026 - 7:25 PM |
