> Egr Resistor mod, Where to put the resistor?
post May 1, 2007 - 6:12 AM
SpyderGS
Joined Apr 22, '03
From Cincinnati
Hey guys, So my engine threw a EGR malfunction code last week, and i don't wanna shell out $90 for a new egr valve. I've read your guys have put a transistor in the EGR sensor and had success. I have a 97 7afe, and can't figure out where the egr sensor is. For the resistors, i've bought 4.7k ohm resistors, but they don't really help if i don't know where to put them. Anybody know? thanks
post May 1, 2007 - 6:59 AM
Hanyo
Joined Aug 16, '03
From Bay area
try cleaning your egr filter first. you will find the egr on the intake manifold near the firewall.
see where the all those vaccuum line are near the airbox resinator thing. Well that is the egr. I assume the senser is also in that area.
remember, the resistor will only remove the check engine light. your car will still fail smog, and pollute the air.
post May 1, 2007 - 8:09 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Down under/behind the intake manifold theres the plug for the egr temp sensor and some other egr sensor... I threw a code on mine also and all i did was get a piece of wire and jump across the terminals on the egr temp sensor connector...code hasnt been thrown since.
This post has been edited by bufferdan: May 1, 2007 - 8:10 AM
Lo-Fi Version Time is now: August 2nd, 2026 - 9:42 AM
