2 Pages V  < 1 2
> Starter just clicks...
post May 10, 2007 - 10:38 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Also, I dunno if this is related, but everytime I push the brake pedal or the window switch, my gauge light/headlights dim down, does this have to do with the battery as well? Because it seems like it could very well be my battery, which is currently a crappy Interstate. frown.gif
-Matt
post May 10, 2007 - 11:47 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
nah, even driving on the highway hitting the window switch to make sure they are up dims the lights, the brake pedal though... unless its just when you are in neutral or have the clutch in and your rpm's drop some thats kinda odd
post May 14, 2007 - 5:47 PM
Jeremiah
Joined Mar 19, '06
From Rocklin, CA
I had a similar problem. It ended up being my ignition switch was worn out / shorting or something. I got it replaced with a used one which is worn out as well... but it works if I don't turn it the key ALL the way round... there's a "sweet spot" where it'll work.
Other things to check:
Battery (Kragen and many places will check for free)
ALL electrical connections - especially ground and terminals
Starter (again - Kragen and many others will check for free)
post May 15, 2007 - 7:48 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Also, I've had a squeaking sound that has come from my alternator on and off, but now it's constant. Could this be the problem?
-Matt
post May 17, 2007 - 9:51 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Anyone?
2 Pages V  < 1 2
Lo-Fi Version Time is now: September 3rd, 2026 - 5:36 AM
