May 10, 2007 - 3:28 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
im planning to putting a turbo into my 5sfe, what im curious abt is that does the intercooler ifself do anything?...it cools down the air so does this mean it increases the hp..or it only works with a turbo kit?
....another thing is how much is for a TRD w2a intercooler kit, not too expensive i hope. cheers. edited: dont worry abt the intercooler question, already know the answer This post has been edited by lubu: May 10, 2007 - 3:44 PM -------------------- ![]() 98% completion --- aaRon |
May 10, 2007 - 6:12 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(lubu @ May 10, 2007 - 3:28 PM) [snapback]556275[/snapback] im planning to putting a turbo into my 5sfe, what im curious abt is that does the intercooler ifself do anything?...it cools down the air so does this mean it increases the hp..or it only works with a turbo kit? ....another thing is how much is for a TRD w2a intercooler kit, not too expensive i hope. cheers. edited: dont worry abt the intercooler question, already know the answer ebay, get it from just-intercoolers You'll have to piece it together but the price and quality are right./ |
May 10, 2007 - 8:31 PM
isnt water to air is better than air to air intercooler though?
there is this complete setup TRD w2a intercooler for 800.dunno if thats a good deal. edit: pic here This post has been edited by lubu: May 10, 2007 - 9:02 PM -------------------- ![]() 98% completion --- aaRon |
May 10, 2007 - 9:30 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
They have both advantage and disadvantages.
There is no such thing as a TRD intercooler. (well, there is a TTE WRC unit of a ST185 rally car) That IC in the picture is ST205 intercooler setup. $AU 800 for the whole setup is not bad at all. BTW, there is a way you can make an intercooler work on N/A car. Heat will only transfer if there is a difference in temperatures. So, using liquid-to-air IC and chilled liquid (lower than ambient temp) will do the job. It'll work as long as you keep cooling the liquid (dry ice etc..) Worth the hp gain and complication?, I don't think so. This post has been edited by Gary: May 10, 2007 - 9:44 PM -------------------- _Gary
May 11, 2007 - 4:15 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(lubu @ May 10, 2007 - 6:31 PM) [snapback]556363[/snapback] isnt water to air is better than air to air intercooler though? there is this complete setup TRD w2a intercooler for 800.dunno if thats a good deal. edit: pic here Looks like this when installed: ![]() -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
May 11, 2007 - 7:17 PM
QUOTE(phattyduck @ May 11, 2007 - 5:15 PM) [snapback]556598[/snapback] That's a stock ST205 intercooler, water pipes and pump with an ST185RC front heat exchanger... That is a nice setup, but works best on a 3rd gen 3s-gte motor. Otherwise, packaging will be an issue. Nope, that is stock ST205 heat exchanger. ST185RC is about 2/3 of that size. -------------------- _Gary
May 11, 2007 - 8:15 PM
ermms....so will these fit on a 5sfe???
May 11, 2007 - 9:01 PM
It will not fit your 5sfte setup due to the location of the throttle body on 5SFE.
Since, 5SFE has side feed manifold, it would be easier to do a FMIC or a barrel wta IC (like PWR). And yes, that is a sticker on the intercooler. See pic of the original one in Charlie's post. By the way, "heat exchanger" is normally referred to the (radiator) unit installed in the front of the car. This post has been edited by Gary: May 11, 2007 - 9:02 PM -------------------- _Gary
May 13, 2007 - 6:37 PM
QUOTE(Gary @ May 11, 2007 - 5:17 PM) [snapback]556664[/snapback] QUOTE(phattyduck @ May 11, 2007 - 5:15 PM) [snapback]556598[/snapback] That's a stock ST205 intercooler, water pipes and pump with an ST185RC front heat exchanger... That is a nice setup, but works best on a 3rd gen 3s-gte motor. Otherwise, packaging will be an issue. Nope, that is stock ST205 heat exchanger. ST185RC is about 2/3 of that size. On my Celica clip: ![]() On my Camry: ![]() Either way, it wouldn't be a good fit for a 5s-fte setup... -Charlie -------------------- 2003 Subaru WRX Wagon
| Lo-Fi Version | Time is now: August 1st, 2026 - 10:40 AM |
