May 14, 2007 - 5:49 PM
Enthusiast ![]() ![]() ![]() Joined May 13, '07 From riverside, ca Currently Offline Reputation: 0 (0%) |
I Dont know how to do it or how to do it ! do i need a compressor ? or just spray paint , how do i spray a clear coat ????? i am a beginner and i would also like someone to walk me through how to take the inserts out fo the door panels ! plz HELP!!!
May 14, 2007 - 5:53 PM
Krylon areosol spray paint in a can, no priming, just scuff it up a bit and clean it with a water /rubbing alcohol mixture then spray it on. as for taking the dash inserts out, drivers side vent, pops out with a bit of force, shift surround pops out with some force, around the radio and vents, there are 2 screws you will see at the bottom where you took the shift surround off, un-do them and pop it off. As for the passanger side vent, i dont know of any one who has taken it off without damaging it, but a pick and some force.
May 14, 2007 - 6:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
I already posted in your other thread about how to do all of this. Please do not make a new thread for something, update your old one.
Take the pieces out, sand them a bit, spray a couple layers of primer, spray a few layers of color, spray a couple layers of clear. You can do it all with spray paint. Go to a hobby type store, somewhere where they sell model cars and buy "Testors" spray paint. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
May 14, 2007 - 7:13 PM
sorry for that , i will make sure i do that next time
May 14, 2007 - 7:59 PM
Enthusiast ![]() ![]() ![]() Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
why no primer...
and where do you get the krylon paint at? or is testors better? This post has been edited by DSToyo: May 14, 2007 - 7:59 PM |
May 14, 2007 - 8:37 PM
i get mine at Canadian Tire and Micheal's craft store
May 14, 2007 - 9:01 PM
i prefer testors model spray cans, they make LOTS of awesome colors, including "boyd" colors (boyd coddington) ect, and since its made for models, it sticks well to the plastic parts.
i do use primer, and sand things down REALLY well to get a nice smooth apperance on them. i start with like 100 grit to get the texture out, and work my way up to 400-600 then primer, color, and clear. make sure you use all one type of paint, meaning, if you buy laquer paint, make sure your clear is also laquer. and same with enamel. good luck! -------------------- Former Team 5SFTE pro member ;)
May 15, 2007 - 11:56 AM
ok , i cant seem to get the door panel apart ! any tips on how to take the panel with all the keys out ??
May 15, 2007 - 12:13 PM
The door panel is one piece. It cannot be taken apart. To take it out you need to remove the triangle that covers your mirror. Just give it a twist and it pops out. There are four screw/bolts along the bottom, 2 on the inside of the door(where the door meets the side of the dash), 3 tabs on the outside of the panel(where it meets the B-pillar area), the screw that holds the trim around the door lever and also one way up inside the handle you grab to pull the door shut. Once all of those are out you should lift up and out. The door panel will come off.
May 15, 2007 - 11:32 PM
Project is Done !! took more time and effort than i thought it would but it looks great ! , i dont own a camera so i cant host any pics , but thanks everybody for all your help
May 16, 2007 - 2:09 PM
Enthusiast ![]() Joined Mar 19, '06 From Rocklin, CA Currently Offline Reputation: 0 (0%) |
Glad it came out looking good. For future reference, I've used Krylon Fusion on plastic parts and had great success.
-Jeremiah |
May 16, 2007 - 9:53 PM
One more Questions for you guys : now i know that using a clear coast helps protects it but what if it is scratch damaged ( in the future0 , any tips on how to touch up the lil paint job ?? also i think i didnt put a thick enough clear coat .. is that bad ?
May 17, 2007 - 9:59 AM
If you don't think you put on enough clear, take it back out, sand it a little, and spray as many layers of clear as you like.
May 17, 2007 - 11:52 AM
Enthusiast ![]() ![]() Joined Jan 6, '03 From Philadelphia Suburbs Currently Offline Reputation: 13 (100%) |
QUOTE(NaderG @ May 16, 2007 - 12:32 AM) [snapback]558227[/snapback] Project is Done !! took more time and effort than i thought it would but it looks great ! , i dont own a camera so i cant host any pics , but thanks everybody for all your help Dude - someone you know owns a camera - u can't tell us how good it looks w/o pics!!! |
May 17, 2007 - 5:28 PM
K, borrowed a camera from work , i have some pics but i dont know how to post them on here
I am planing on painting the trim arround the steering wheel and the gauge , i also changed my gauge lights to blue , and i broke my climate control trying to paint it blue , which didnt eveb work |
May 17, 2007 - 6:14 PM
alright... a lil off topic but, have any of you guys regreted painting your interior peices...i guess im just a little concerned with the heat when you park your car affecting the paint, or the paint getting cracked or faded, idk. i just have never been sold on the idea...it looks good but does it last?
May 17, 2007 - 7:31 PM
QUOTE(DSToyo @ May 17, 2007 - 11:14 PM) [snapback]559011[/snapback] alright... a lil off topic but, have any of you guys regreted painting your interior peices...i guess im just a little concerned with the heat when you park your car affecting the paint, or the paint getting cracked or faded, idk. i just have never been sold on the idea...it looks good but does it last? I Just painted mine so i still havent regreted it yet lol, but as far as i can see , i would repait it a million times again , it really makes the car looks nice and i am sure if you do it the right way , u wont have any problems , atleast not for a reasonable ammount of time |
May 20, 2007 - 11:30 AM
QUOTE(DSToyo @ May 17, 2007 - 7:14 PM) [snapback]559011[/snapback] alright... a lil off topic but, have any of you guys regreted painting your interior peices...i guess im just a little concerned with the heat when you park your car affecting the paint, or the paint getting cracked or faded, idk. i just have never been sold on the idea...it looks good but does it last? i know what you mean. i had the same concern . best thing to do is to buy a 2nd pair of all the plastics you want painted. that way, if you mess up, or change your mind, you can always go back to your stock ones. you could also take them to a body shop and ask them to paint them for you. it would probably cost about 100bucks or so to do. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 24, 2007 - 9:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) |
nah i love my interior painted it turns heads, and i always get asked who did that for one...i'll be like no one I did...that never gets old
May 24, 2007 - 10:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
To post pics on forums u have to find a site that will allow you to get the URL or HTML code for it,just about everyone uses photobucket.com,its complety free and allows you to post in your threads,signitures,and avitars.Anyway i was thinking of painting my interior silver in a while,does anyone have pic or this or photoshop?
-------------------- BANNED. for life, you moron.
| Lo-Fi Version | Time is now: September 11th, 2026 - 7:49 PM |
