> It was past time......lots of new suspension pics!
post May 14, 2007 - 9:56 PM
bhawk94
Joined Dec 5, '05
From Clemson, SC
I installed KYB GR2 shocks and struts and Tein S-Tech springs this weekend finally. This was my first time dealing with suspension and I pretty much did it by myself. (Just in case there are some other noobs wondering if they can do it) Overall I am pleased with the setup. I drive my car everyday and I literally work in my car. I wanted a setup that wasn't so low that it would scrape all the time but still have an aggresive stance, improve handling, and ride well. I ran into 2 problems with the install one of which I included in the pics and showed how I handled it. The other problem was with getting the 19mm upper bolt loose from the strut and the knuckle on the rear. It was really stuck and I broke 2 sockets on it. I ended up using a high impact socket with a breaker bar to get it loose
Here are the nuts that came out of the stock front strut casings (rebuildable). This must be removed in order to get the stock shock out and put the new one in. It is 2 1/8'' wide, so you have to use a huge adjustable wrench or a boxed in 2 1/8'' wrench to get it off and put the new nut on (these come with the GR2's). As you can see, I ended up putting a notch in the nut with a screw driver and hammer. I kept hitting it around until it came loose because the wrench kept rounding off the corners. I used the boxed end of the big wrench to put the new one on after replacing the strut with no problem.
This is one of the rear struts completed with the spring, spring bumpers, brand new dust guards, etc. The rears are full replacements, not rebuildable.
Before install.......
After install........
Now some pics after I washed it........
I've driven about 300 miles and it rides great. It hits bumps a little harder but it's not bad at all. It pulls a little to the left. I'm probably going to get an alignment in a few days but the tires seem to be wearing fine and no camber issues to speak of. Let me know what you think, good or bad!
- bhawk94   It was past time......lots of new suspension pics!   May 14, 2007 - 9:56 PM
- - 95st-celica   looks really good man i was actually thinkin about...   May 14, 2007 - 10:01 PM
- - bhawk94   KYB's and Tein's from E-Bay. Got both for...   May 14, 2007 - 10:06 PM
- - purplegt4   absolutely perfect. good work. get that alignmen...   May 14, 2007 - 11:11 PM
- - celicast3sgte   you ummm... have my wheels.. haha jk how are ya...   May 14, 2007 - 11:31 PM
- - jason   and watch for overdriving your headlights. ^^^ g...   May 14, 2007 - 11:37 PM
- - bhawk94   Not sure what "over driving my headlights...   May 15, 2007 - 8:06 AM
- - GTS13   Now you just need bigger sways and you'll real...   May 15, 2007 - 2:12 PM
- - m0dd3d1   Yeah, can someone explain "don't overdriv...   May 15, 2007 - 7:32 PM
|- - bhawk94   QUOTE(m0dd3d1 @ May 15, 2007 - 7:32 ...   May 15, 2007 - 8:38 PM
|- - m0dd3d1   QUOTE(bhawk94 @ May 15, 2007 - 8:38 ...   May 15, 2007 - 9:11 PM
- - Kwanza26   I like the wheels... although IMO... 225 are a tou...   May 15, 2007 - 7:39 PM
- - bhawk94   I have Chilton too. I got the dust/dirt shields f...   May 15, 2007 - 9:36 PM
- - illneversellmycelli   small world, i have the same setup, got my suspens...   May 15, 2007 - 9:47 PM
- - jason   overdriving your headlights: get a fast car with d...   May 15, 2007 - 10:29 PM
- - bhawk94   Thanks for the clarification on the "over dri...   May 15, 2007 - 10:46 PM
- - purplegt4   QUOTE(jason @ May 15, 2007 - 11:29 P...   May 15, 2007 - 11:27 PM
- - m0dd3d1   Thanks for the definition! So just for clarif...   May 15, 2007 - 11:28 PM
- - bhawk94   You may not need the dust covers. Look at your sh...   May 16, 2007 - 7:49 AM
|- - m0dd3d1   QUOTE(bhawk94 @ May 16, 2007 - 7:49 ...   May 16, 2007 - 6:48 PM
- - bhawk94   Camber is the when the wheel leans in or out. If ...   May 17, 2007 - 1:06 AM
- - bhawk94   Got an alignment this morning at Sears. They seem...   May 18, 2007 - 9:34 AM
- - bufferdan   Good choice on everything! I like it lots   May 18, 2007 - 11:41 AM
- - kbprice   I just finished doing mine this morning also. I t...   May 18, 2007 - 3:15 PM
- - kbprice   One other thing that I figured out was that the fr...   May 20, 2007 - 6:51 PM
- - tim86   that drop looks awesome kb... sometime soon when i...   May 20, 2007 - 8:58 PM
- - tceligt   Super clean a nice ride, good job.   Jul 26, 2007 - 5:53 PM
Lo-Fi Version Time is now: August 27th, 2026 - 10:47 PM
