May 17, 2007 - 1:11 AM
Enthusiast ![]() Joined Sep 29, '06 From US Currently Offline Reputation: 3 (100%) |
I have a 1997 celica gt convertible limited edition, and my problem is that I bought a set of kyb's from ebay. The front struts are not the same as the ones in my celi, first the bottom bolt holes on the stock ones are further apart than on the kyb's and also the stock stuts are a little bit bigger than the kyb's. I know the guy dindn't send me the wrong ones because I checked the part number and it matches with other stores.
----PLEASE HELP---- DOES the limited edition have anything to do with this. |
May 17, 2007 - 1:32 AM
got pics?
got pics? -------------------- ![]() |
May 18, 2007 - 3:31 PM
![]() Enthusiast ![]() ![]() Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Did you get two inserts and two full replacements? Pictures would really help. It could be possible you got the superstrut parts...
May 18, 2007 - 8:20 PM
Enthusiast Joined May 3, '07 Currently Offline Reputation: 0 (0%) |
ok i would put down 50 bucks that I have the answer to your problem. Take the kybs that your trying to put on the front, and put them on the back because they are the back struts. The holes on the back are further apart. Next I'm guessing you have two skinny little boxes that just look like a shock alone. Thats because there strut inserts, or cartridges. Take out your front struts and there is a little nut that holds the insert on, you can remove it using a set of channel locks. New nuts should have also come with the strut. Remove old strut cartridge and install the new one then install the new nut, if you didnt get new nuts just use the old one. I attempted to do the same thing as you are doing the first time I did it so I know exactly what is going on. I also looked up the part numbers because I thought I had the wrong stuff. This post has been edited by Newb: May 18, 2007 - 8:21 PM |
May 21, 2007 - 4:13 PM
Yeah. ^ That's what I was trying to get at. The front two are rebuildable and the back aren't. So you should have two that are inserts for the front.
May 21, 2007 - 9:35 PM
QUOTE(GTS13 @ May 21, 2007 - 9:13 PM) [snapback]560109[/snapback] Yeah. ^ That's what I was trying to get at. The front two are rebuildable and the back aren't. So you should have two that are inserts for the front. yea he pmed me and said thanks i was indeed right. I only knew so fast cause I tried to the exact same thing, I felt some stupid after I figured it out though lol. Probley why he never publicly posted it. ebay ftmfw!!! |
May 24, 2007 - 7:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
QUOTE(GTS13 @ May 18, 2007 - 3:31 PM) [snapback]559320[/snapback] Did you get two inserts and two full replacements? Pictures would really help. It could be possible you got the superstrut parts... Wow, SuperStruts I would love to see the day some guy on ebay sends me a wrong set containing these. |
Jun 1, 2007 - 3:36 PM
QUOTE(Newb @ May 21, 2007 - 9:35 PM) [snapback]560263[/snapback] QUOTE(GTS13 @ May 21, 2007 - 9:13 PM) [snapback]560109[/snapback] Yeah. ^ That's what I was trying to get at. The front two are rebuildable and the back aren't. So you should have two that are inserts for the front. yea he pmed me and said thanks i was indeed right. I only knew so fast cause I tried to the exact same thing, I felt some stupid after I figured it out though lol. Probley why he never publicly posted it. ebay ftmfw!!! Yeah I freaked out when I got mine thinking they sent me the wrong thing, I was pissed. Then I figured out that the front were rebuildable, a cigarette later and my nerves were calmed. -------------------- |
Jun 6, 2007 - 10:42 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Same thing happened to me. I thought I got the wrong ones at first, hah. I felt stupid later.
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:41 PM |
