May 18, 2007 - 4:00 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
I need some help removing the hard brake lines from the frame bracket. I got some SS lines and am trying to take off the stock rubber ones and it just isn't working out...
I took the whole brake assy off (caliper/pads/rotor) and "drained" the fluid out of the line (let it drip into a jar). I got one side off (fronts only, haven't started on rears) but can't seem to get the other off. I have a pair of visegrips clamped onto the bottom under the bracket along the solid part, just under the flare nut, and that seems to be gripping ok. The part I'm having trouble with is the 10mm nut on top of the bracket. I got the first one off by using another set of visegrips and just muscled it, but the 2nd one keeps rounding. I've been at it for the last 2 hours, broke a wrench trying to get this sob off and have cuts all up my arm from when the nut rounds off and my arm scrapes inside the wheel well... Visegrips don't seem to be working on this side either as they just round the nut off more. Any help? Is there such a thing as a "3 point" open end wrench. All the ones I have are just 2 points with a curved middle. |
6gsillyca Removing hard brake lines from frame bracket May 18, 2007 - 4:00 AM
Coomer You need a good quality line wrench. It slides ove... May 18, 2007 - 6:46 AM
6gsillyca Is a line wrench the same as a flare wrech? May 18, 2007 - 12:14 PM
Coomer Yeah. Make sure you get a good quality one. The fi... May 18, 2007 - 5:40 PM
playr158 if you mess up the fittings, use a set of vice gri... May 18, 2007 - 6:08 PM
6gsillyca I haven't messed up the fittings too bad yet, ... May 19, 2007 - 12:46 AM
playr158 use the styled pictured above.
and tighten them s... May 19, 2007 - 7:12 AM
Bitter use a torch to heat the fitting as well, that... May 21, 2007 - 6:07 PM
6gsillyca Got em all off. Got a nice set of flare's but ... May 25, 2007 - 1:59 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 12:33 PM |
