> any one install a NEO on a 5s yet??
post May 19, 2007 - 2:11 PM
Valo666
Joined May 15, '05
From Toronto
So, i bought my self a Apexi AFC Neo today, and am plannin on wiring it up on tuesday when i have class. Has any one wired one of these up to a 5s yet?? I know Steph got one wired up to her ST, but not 100$ sure about any one with a GT. i donno if its like the SACFII, but its got a 15 wire wiring harness, but it says for a non v-tec, non RB26DETT, and a non- karman sensor vehicle, only use 9 of the wires. So pretty much you only need these wires: IG power, IG power *again*, RPM, throttel, ground, ground, airflow/pressure sensor, airflow/pressure sensor and illumination *ie power*. Does any one have a pic of a 5S pinout that can highlight these wires for me? Thanks
Bryan
- Valo666   any one install a NEO on a 5s yet??   May 19, 2007 - 2:11 PM
- - Dr_Tweak   I whipped this up for you real quick, it's usi...   May 19, 2007 - 2:32 PM
- - Valo666   ty tweak. can some one with a stick verify this is...   May 19, 2007 - 3:23 PM
- - Dr_Tweak   Just compare it against the instructions, the Toyo...   May 19, 2007 - 3:51 PM
- - Valo666   they dont list a 5sfe though, only 3sfe and i wann...   May 19, 2007 - 5:13 PM
- - 6strngs   yeah, I've got one in my car. and yeah, it...   May 20, 2007 - 6:10 PM
|- - Dr_Tweak   QUOTE(6strngs @ May 20, 2007 - 11:10...   May 20, 2007 - 10:17 PM
- - Valo666   thanks dude.   May 20, 2007 - 11:45 PM
- - LewFX   on my car there pressure wire is missing from the ...   Nov 10, 2007 - 8:30 PM
|- - presure2   QUOTE(LewFX @ Nov 10, 2007 - 9:30 PM...   Nov 11, 2007 - 8:41 AM
- - 6strngs   might be in a different place though cause you hav...   Nov 12, 2007 - 1:38 AM
- - LewFX   what color is the pressure wire? i tapped a blue o...   Nov 12, 2007 - 1:55 PM
- - LewFX   anyone know what color the pressure wire is??   Nov 13, 2007 - 1:04 AM
|- - urbandork   QUOTE(LewFX @ Nov 12, 2007 - 10:04 P...   Nov 13, 2007 - 1:34 AM
- - LewFX   i dont have any grey blk wire, can anyone else can...   Nov 13, 2007 - 9:55 PM
- - lagos   on the middle ecu plug, pin 2 from the right when ...   Nov 13, 2007 - 11:49 PM
- - LewFX   okay i checked the map sensors wires, its brown, b...   Nov 13, 2007 - 11:58 PM
- - MaskedMan   Yes, the #2 wire coming from the Map sensor is blu...   Nov 14, 2007 - 12:45 AM
Lo-Fi Version Time is now: August 31st, 2026 - 11:57 PM
