May 20, 2007 - 10:20 PM
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
Guys,
Did some research, and apparently the transmission that comes with the 94+ SS2 Celica (the one with the super-strut) is not a S54, but an E56 transmission. I've known about this trans for a couple of years now, but I never really thought anything of it til now - this is an E series trans mated to a 3S in a 6G gen FWD Celica!!! What's the possibility that the stock axles for this car would fit the MR2's E153 trans - giving us the perfect length axle? I've swapped between the super-strut and standard suspension on my car, and I can say that the hub placement is the same - so that wont be an issue. Now the part that worries me - this trans is also offered in other (non performance) cars ,though with different gearing and such. A few of these cars are available stateside: 88-90 AE95 Corolla 90-93 AE95 Corolla wagon. 95+ AE103 Corolla 94+ SXA Rav 4 If I get some time, I may go out and pick up an axle from one of these cars and see if it will fit the MR2's splines. If it works, I'll see what pricing Jeff @ Champion Toyota can get. Here are the part numbers if anyone is interested: drive shaft, RH : 43410-20690 SS2 Celica w/SSS drive shaft, RH: 43410-20700 SS2 Celica w/SSS w/ABS This post has been edited by scothaniel: May 20, 2007 - 10:20 PM -------------------- Scott
West Michigan |
scothaniel Possibly another solution to the E153 axle problem May 20, 2007 - 10:20 PM
toyotacrazy what engine is this mated with and where is the ca... May 21, 2007 - 5:17 AM
scothaniel JDM / European model with a 3SGE (non-beams). May 21, 2007 - 8:44 AM
phattyduck '88-'91 V6 5-speed Camry axles fit perfect... May 21, 2007 - 12:59 PM
Rjb23 91 Camry axles will not fit, the splines are diffe... May 21, 2007 - 3:47 PM
phattyduck QUOTE(Rjb23 @ May 21, 2007 - 1:47 PM... May 22, 2007 - 1:42 PM
eggman40 QUOTE(Rjb23 @ May 21, 2007 - 1:47 PM... May 24, 2007 - 10:03 PM
phattyduck QUOTE(eggman40 @ May 24, 2007 - 8:03... May 24, 2007 - 11:47 PM
CilverSeliST205 Did anyone else confirmed that this combo works wi... Oct 1, 2007 - 9:24 AM
1900 all you have to do is change the outer c.v. joints... May 21, 2007 - 7:21 PM
scothaniel Providing they are the correct length. May 21, 2007 - 10:33 PM
scothaniel I picked up the camry outer axles before any they ... May 22, 2007 - 2:52 PM
WannabeGT4 Not the Camry axle debate again... The older, 1990... May 22, 2007 - 3:58 PM
phattyduck QUOTE(WannabeGT4 @ May 22, 2007 - 1... May 22, 2007 - 10:02 PM
Rjb23 QUOTE(WannabeGT4 @ May 22, 2007 - 8... May 23, 2007 - 6:01 PM
WannabeGT4 QUOTE(Rjb23 @ May 23, 2007 - 6:01 PM... May 24, 2007 - 7:54 AM
scothaniel Has anyone tried the Rav 4 or Corolla all-trac wag... May 24, 2007 - 3:00 PM
scothaniel And this requires no spacers to work, unlike the M... May 24, 2007 - 11:18 PM
eggman40 QUOTE(scothaniel @ May 24, 2007 - 9... Jun 6, 2007 - 1:42 AM
Alan QUOTE(eggman40 @ Jun 6, 2007 - 1:42 ... Oct 2, 2007 - 2:23 AM
Supersprynt I'll tell you this much, I wish I never went E... May 25, 2007 - 12:07 AM
Alan I WANNA DO THE E153 SWAP BUT I HAVENT READ ONE THR... May 25, 2007 - 3:27 AM
urbandork Super out of the blue but...
....whats so great ... Oct 2, 2007 - 3:07 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 12:07 AM |
