> Stereo Help
post May 30, 2007 - 12:28 PM
tcox22
Joined Jul 26, '05
From New Carlisle, IN
I just received my new Pioneer DEH-P7800MP and I have a harness adapter already but I was wondering what mount do I need to buy?
post May 30, 2007 - 1:00 PM
Valo666
Joined May 15, '05
From Toronto
if its just a regular din hook up *2 screws per side*, you should be able 2 use the oem mount.
post May 30, 2007 - 1:07 PM
tcox22
Joined Jul 26, '05
well, what all do i need to buy? i had best buy install my first after market stereo, so i have no idea what they did. i just got that one stolen, so i figured i'll save some money by installing everything myself.
post May 30, 2007 - 1:21 PM
bman
Joined May 14, '07
From Long Island
if the left and right brackets weren't stolen too then just use those it will bolt right in - they hold anything and everything
if besty buy did it they may have cut out the factory harness plugs so you may have to hard wire it -
94 Celica ST - CAI, CarPuter, many interior mods!
post May 30, 2007 - 1:24 PM
lubu
Joined Apr 2, '07
From Great Western Plateau
use ur existing oem mount, if you still have it then you dont need to buy anything...
98% completion
aaRon
post May 30, 2007 - 1:52 PM
tcox22
Joined Jul 26, '05
well, the OEM mounts got jacked with the stereo. can i just buy something like this? http://www.bestbuy.com/site/olspage.jsp?sk...d=1051384099285
post May 30, 2007 - 5:26 PM
bman
Joined May 14, '07
From Long Island
I used the best buy "compatibility guide" and it said it does not fit the celica -
you may have to call a junk yard or two! if it was my situation thats what I would wind up doing...
post May 30, 2007 - 6:05 PM
Redline08
Joined Feb 23, '07
From Albany, NY
yea, my first stereo installation on the celica was a nightmare, DONT BUY ANY HARNESSES, if u allready have thats fine but i tried to different companies harnesses, 40 dollars each set ( 2 in each set [one connecting to the celica and the other to the radio]) both sets failed and i had to hardwire everything,
the hardest part is to not get the power wires mixed up, there is one power wire coming from your celica that only gets power when the parking lights and headlights are on, and there is another power wire that is always on unless you shut off the car.
So when you hook up the stereo make sure you dont have the headlights on and everyhting should go smoothly, its actually really easy if you have wire strippers and such...
OOO btw for the mounts your gonna have to go to a junkyard because im almost positive no one sells the actual stock mounts.
post May 30, 2007 - 10:35 PM
tcox22
Joined Jul 26, '05
so could I get summed up exactly what I'm going to need? Since everything got stolen basically, it'll be like starting from scratch. I'm aware that I'll need something to fill in the double din slot since the stereo is only a single din. I know best buy sells something that does fit, because they gave me something when i had my stereo installed there in the first place. I also have a wire harness adapter and i already have everything taped off, all i need to do is solder for the most part.
Edit:
The stereo
heres the back, for the little blue circle auxiliary input could i take an auxiliary cable from that and plug it into my ipod? i don't feel like spending 50 bucks on a stupid ipod interface thing.
all of the wires on my wiring harness adapter match up perfectly except the system remote control wires, should i cut the wire coming from the Pioneer wire harness and solder it to the harness adapter? the ground wires don't match up either but i understand both of those will need to be separately grounded and the mute wire i'll tape off or something
This post has been edited by tcox22: May 30, 2007 - 10:57 PM
post May 31, 2007 - 6:31 AM
bman
Joined May 14, '07
From Long Island
that input SHOULD work fine -
soldering/splicing those blue wires is fine too -
I just realize now you'll have a 1 din hole in your car... hmmm i suppose you could get creative with cup holders (out of a ford taurus), buy a new "bs holder" from a junk yard along with your two brackets, or whatever else you wanna spend money on
Or if you cant find something to fill the hole, make something. cut a piece of plexiglass/lexan and paint it the color of your choice and use that as a "blank" - attach it to the back of the bezel piece with some epoxy (or something)
P.S - when you call the junk yards i would call the pieces "radio brackets from the dashboard" and "the storage pocket under the radio" so they have a good idea of what your talking about
EDIT: One more thing! I've learned from friends and personal experience that when your car gets broken into the thief will almost always return to see what you bought to replace what he stole originally! Keep the radio face out of the car so if/when he comes back he at least doesn't get a radio out of it!
This post has been edited by bman: May 31, 2007 - 6:33 AM
post May 31, 2007 - 8:08 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
[/quote]
call up your local toyota dealership, you just ask for a right and left mount for an aftermarket headunit.... about 5 bucks apice, and just ask for one screw and take it to autozone/ or a hardware store and get the matching ones for a lot cheaper*
you also may want to buy a "spacer/slot" it mounts ither above or below the headunit, theres one w/ a door for around $35 or w/o a door for $7
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
post May 31, 2007 - 8:20 AM
tcox22
Joined Jul 26, '05
thanks guys. i think i'm heading off to the toyota dealership today to get the OEM mounts and i'm gonna swing by best buy and ask them for the same piece they used to fill the extra slot from my other pioneer stereo.
oh, and another thing while i'm at it, my stock alarm system is disconnected (it was when i bought my car) how would i go about reconnecting it. i don't really know much about the stock system and i do not have a remote or anything to turn it off, so i'm pretty lost.
post Jun 2, 2007 - 11:56 AM
Redline08
Joined Feb 23, '07
From Albany, NY
i never think about that, theres something about dealerships that screams rip off, junkyard would prolly be cheaper, and if its not just go there in person and ask to get a screw/bulb yourself and jack the radio mounts, they fit in your pocket.
post Jun 2, 2007 - 12:12 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
look for something called "iso" mounting, thats what those brackets are called i believe, the 2 blue wires are for your amp, one with spade end is hot, one without is not, you can run that to the amps remote separately or tape off if you dont have subs, if you need mounting pieces, i think i still have mine from when i had a single din radio, new they are like $15-30 depending on where you go, but if you want mine its urs
post Jun 4, 2007 - 6:53 PM
Manny
Joined Feb 8, '07
From Oakland, Ca USA
If you are talking about the AUX pwr blue wires.... there is a double connector for a reason. 1 is to power your amp and the other side is to power your antenna.
I have a Pioneer myself....
-M-
post Jun 4, 2007 - 7:34 PM
I have that same deck and its a great deck. I would recommend the Ipod Interface so that you could use the remote to go through songs and albums, but it takes awhile. You have to scroll all the way through.
The remote wire is only necessary to use if you have an aftermarket amp.
This post has been edited by Supersprynt: Jun 4, 2007 - 7:37 PM
post Jun 7, 2007 - 2:12 PM
tcox22
Joined Jul 26, '05
so i got the mounts and everything but i still need the extra thing that covers up the double din slot. toyota wants to charge like 30 somethin bucks for the one with the door, would anybody happen to have the part number for the one without the door?
Lo-Fi Version Time is now: August 21st, 2026 - 7:16 PM
