> wheel size
post Jun 1, 2007 - 5:49 PM
NaderG
Joined May 13, '07
From riverside, ca
What is the best size of tire to put on 17 and also 18 inch rims so that it would looks good and not rub or anything on a stock hieght car , would it throw off the speedometer??
also , incase i wanted to upgrade my suspension , what is the smallest drop possible ? like 1 inch or even half ... and if so , then what tire size should be used ?
This post has been edited by NaderG: Jun 1, 2007 - 5:51 PM
post Jun 1, 2007 - 7:29 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
imo:
17 225/40/17 x7.5
18 225/35/18 x8
i have the later and cannot complain, you could prolly drop 1-1.5 inches no prob, on mine i see a problem with the wheel plastics which you can just bend(dent) in so theres more clearance
most tire places *should* let you test fit some tires before you commit to buying them, from what i know/believe it depends alot on your width and offset
speedometer wise, your talking like 3-4 mph off at like 70/80 ish speeds so i wouldn't worry about that, unless you go smaller, the wheel wells wont fit too big of tires comfortably to have an issue there
comes down to which look you prefer better, i for one like a lower profile wide tire on a larger rim, others like different, find something that is happy and go with a common tire size for price reasons, if your unsure, get some cheap tires to try for a while to see how you like the look/ride, if both are bearable, great, if the ride quality goes to hell, get some bigger tires
really low profile tires, dubbed "ruber bands" aka what i used to have are AWESOME for cornering but watch out for them pot holes......
post Jun 2, 2007 - 12:14 PM
NaderG
Joined May 13, '07
From riverside, ca
QUOTE(jason @ Jun 2, 2007 - 12:29 AM) [snapback]563960[/snapback]
imo:
17 225/40/17 x7.5
18 225/35/18 x8
i did some reasearch on the site ( should have done that before i put the post) and that tire size seems to be everybody's favourite , my question to you is what is the "x7.5" and "x8" that u put after the sizes ??
post Jun 2, 2007 - 9:04 PM
jason
Joined Oct 7, '06
ookay
225 width of tire
40 percentage of width that is the thickness
18 wheel size/inner size of tire
8 width of wheel
so 225/40/18x8 =)
post Jun 2, 2007 - 9:23 PM
NaderG
Joined May 13, '07
From riverside, ca
i actually knew the rest , but thanks for your help !
one more things , will the speedo be 3-4 miles faster , or slower than it shows
This post has been edited by NaderG: Jun 2, 2007 - 9:24 PM
post Jun 2, 2007 - 9:52 PM
jason
Joined Oct 7, '06
bigger tire diameter speedo will show slower
smaller tire speedo will show faster
a 205 tire to a 225 tire will maybe be off by 3mph
post Jun 3, 2007 - 3:11 AM
Kadett
Joined Mar 17, '05
From The Netherlands
I wouldn't go with 35/18 tyres, I'm relacing them with 40/18 tyres.
post Jun 3, 2007 - 4:22 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(Kadett @ Jun 3, 2007 - 1:11 AM) [snapback]564369[/snapback]
kadett do me a favor, before you replace those tires. Can you take a picture of your car directly from the side? And then after you get your new tires take the same picture again..
I would love to see how 40 series tires look on 18 inch rims.
post Jun 3, 2007 - 4:30 AM
Kadett
Joined Mar 17, '05
Will do,
Still have the 225/35/18 tyres (Toyo Proxes) but after 9000 miles the thread is gone ,stupid 3S-GTE eating up all of the thread biggrin.gif:D. Anyhow, wil make pictures from the side before and after the new tyres are on. The 225/40/18 will go to the back first because otherwise it will look even more funny with bigger front then rear tyres.
Then it will be another 5k miles before the front tyres are worn down I think.
post Jun 3, 2007 - 11:51 AM
jason
Joined Oct 7, '06
why not a 35 on an 18 rim? the difference i notice from a 225 40 to a 225 35 isint that much, and the 35's dont rub where as the 40's did. what offset do you have? and for 18's i wouldnt recommend going less that 225 again, but the 35's i have on now seem to work nicely
post Jun 3, 2007 - 12:00 PM
Kadett
Joined Mar 17, '05
I have 18x7.5J wheels with an ET48 offset. In the front I have 15mm spacers making the ET effectively 33 and in the back a 20mm spacer making the ET 28.
Since my rims are .5" smaller then yours (i assume you have an ET 35) I will have more room on the inside and outside of the tyre.
post Jun 5, 2007 - 1:35 AM
jason
Joined Oct 7, '06
ah i went with a 30mm offset so whatever difference that comes out to
post Jun 5, 2007 - 11:43 AM
NaderG
Joined May 13, '07
From riverside, ca
will theese sizes fit in the car with the soft stock springs ?
post Jun 5, 2007 - 7:47 PM
jason
Joined Oct 7, '06
yes, fitting is easy with stock ride height(springs) issues occur when lowering, what i have at full turn fits BARELY dropping the car 2.25 inches about in the front and rear the fenders have to be slightly rolled, but you have a coupe/vert rear end as well and from what i hear its a bit wider than hatches, imo a 1.5 inch drop is nice on these cars smile.gif
post Jun 17, 2007 - 11:30 PM
KB-2
Joined Jul 6, '06
http://wheelsnext.com/default.cfm?action=d...GLOSS%20FINISH)
what does everyone think about these badboys???huh?
uhmmm would those fit okay?
im prolly getting rims by the end of the summer....so yea...
and im also gonna drop it....but im not sure how much yet.
KB
post Jun 18, 2007 - 11:36 AM
KB-2
Joined Jul 6, '06
BUMP
KB
post Jun 18, 2007 - 12:18 PM
Kadett
Joined Mar 17, '05
Black rims + polished lip always looks good on a White car. These will do just fine.
But what about the offset/ET? It doesnt state that anywere.
post Jun 18, 2007 - 12:20 PM
KB-2
Joined Jul 6, '06
yea...i have no clue with the offset.....actually i dont know what that even means or waht size? offset i need.....ill try to find the compans website or something later....
KB
post Jun 18, 2007 - 1:11 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If you were to get 17's do not get 225/40R-17 tires.
I mean, you can get 225 if you want, but for a 7" wide wheel (which is what most 17's are anyways) I would suggest 215/45R-17
**** Photobucket
Lo-Fi Version Time is now: June 25th, 2026 - 10:50 AM
