Jun 6, 2007 - 7:25 PM
Enthusiast Joined Apr 16, '05 Currently Offline Reputation: 0 (0%) |
I went under to change my tranny fluid today and totally stripped the drain bolt/plug. It's so narrow in that area I couldn't really get a good grip ( i don't know how I managed to drain it before...). Successive tries just resulted in more and more stripping, and now I can get the socket onto bolt, but it just slips off if I try and turn it
Jun 7, 2007 - 9:45 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
If it is stripped out I would go ahead and take it to your mechanic, or you can try and drill it out and go down to the dealership and buy a new one.
Jun 7, 2007 - 10:09 AM
make two sides flat with a file, spray it with pb blaster and grab it tight with pliers, then turn. that should do the trick.
Jun 7, 2007 - 11:13 AM
What you need is a Bolt-Out set, or maybe you can just find the one you need.
![]() You can find them at sears, make sure it has the size you need. This post has been edited by Supersprynt: Jun 7, 2007 - 11:16 AM -------------------- |
Jun 7, 2007 - 10:30 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
QUOTE(x_itchy_b_x @ Jun 7, 2007 - 9:09 AM) [snapback]566048[/snapback] make two sides flat with a file, spray it with pb blaster and grab it tight with pliers, then turn. that should do the trick. i would do that but use vice grips. i had to do that once on a mercury tracer oil drain plug. it had seized because i lost the washer the last time i changed the oil. but that is a sure method to get that sucka off. -------------------- |
Jun 7, 2007 - 10:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
uses vice grips and give them some nice taps with a hammer.
Jun 7, 2007 - 10:51 PM
1st off... make sure your using a 6point socket...not a 12point.
a bolt out would get it off in about 1 sec. problem is they dont make 24m bolt outs dont drill it. metal shavings will get inside your tranny. try itchy's trick, or get a plumbers wrench. they are made for rounded surfaces. if all else fails, take it to a shop. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 7, 2007 - 10:56 PM
Vice grips destroy lives.
| Lo-Fi Version | Time is now: August 25th, 2026 - 6:43 PM |
