> Headlights dimming, just when i turn on my fogs
post Jun 6, 2007 - 7:53 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
something i noticed on my car last night when i was driving. if i just have my headlights on it seems that they are brighter than when i have both them and my oem fogs on. has anyone else noticed that on their car? is there a relay or something that would cause that or do i just have a weak battery? nothing serious just something i would ask about.
also what is the bulb # on the silverstars for the lowbeams?
thanks guys
post Jun 6, 2007 - 8:04 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
If your driving and they dim, it's probably your alt. Do you have a system in there?
post Jun 6, 2007 - 8:11 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(coldbluesteel @ Jun 6, 2007 - 7:04 PM) [snapback]565839[/snapback]
yeah but it is just a small one
post Jun 6, 2007 - 8:34 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Probably a weak alternator then.
post Jun 6, 2007 - 9:29 PM
Gary
Joined Aug 28, '04
From FLA USA
How old is your battery?
_Gary
post Jun 6, 2007 - 9:35 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(Gary @ Jun 6, 2007 - 8:29 PM) [snapback]565869[/snapback]
8 mo is all. i noticed it before i got the sub though. it's not like they are way dim just a little bit. i want to put the silverstars in eventually since i don't have the cash for HID
post Jun 6, 2007 - 9:56 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i got a spare alternator off my 99 for sale if u need one
post Jun 10, 2007 - 11:06 AM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
the best way to tell if your alt. is on the way is when idling and you rev, your lights go brighter.
you can measure the running voltage of your alt. with a voltmeter, it should read 13.9V to 15.1V when engine is cold and 13.5V to 14.3V when hot. You can also measure the drop when you turn on your fog lights.
Another thing, how did you wire up your fog lights? If you use the headlight wire for power, this would be the reason why everything is going dim. That little wire can't handle the draw and causes a voltage drop when high current is trying to pass thru.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jun 10, 2007 - 3:01 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(K-ESD @ Jun 10, 2007 - 10:06 AM) [snapback]566857[/snapback]
they are stock fogs. and my lights don't get brighter if i rev in idle. they used to but that was because of a bad battery clamp not making a very good connection. but that was fixed months ago.
i don't know what it is. maybe it is just my eyes playing tricks on me. oh well. i am pretty sure it isn't the alternator.
oh well. nbd
thanks guys for your input.
post Jun 11, 2007 - 5:43 AM
cnelson
Joined Dec 11, '06
From New Jersey
how much would a good alt. cost? jw..
"Drive Well...
...Drift Better"
post Jun 12, 2007 - 10:42 AM
LewFX
Joined Jan 28, '05
around 100 for rebuilt, used for 50, new is 150+
what about the start your car and then pull the negative cable off the battery, if she dies then your alternator is bad?
This post has been edited by LewFX: Jun 12, 2007 - 10:42 AM
post Jun 12, 2007 - 11:23 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
my friend had this problem with his bonneville with a factory setup....everytime he would switch to the fogs or switch to highbeams the low ones would get slightly dimmer...What he did was run them on a stand alone switch without a relay...they now are crazy bright.
post Jun 13, 2007 - 12:58 PM
topshed
Joined Jan 8, '07
From Sunderland UK
Could be a bad earth of course.
post Jun 13, 2007 - 2:01 PM
Hanyo
Joined Aug 16, '03
From Bay area
yea it sounds like a bad ground.
does your lights dim some more when you hit the brakes?
if your rev your engine and your lights don't get brighter, then its not a power/amp issue. There is something restricting the electricity from flowing. try to ground your fog lights directly to your battery.
that should solve your problem.
Lo-Fi Version Time is now: July 30th, 2026 - 3:50 PM
