> Speed Sensor
post Jul 27, 2003 - 6:53 PM
TrDcElica6thgen
Joined Nov 18, '02
From Belmont, CA
i was taking a look at the "Terminals of Engine ECU" and i noticed a terminal named "speed sensor". Anyone know if this is releated to the speed limmiter?
Replies (1 - 7)
post Jul 27, 2003 - 10:27 PM
The speed sensor is actually on ur tranny. It reads how fast your going and sends that to the ecu, the ecu in turn tells the speedo. The limiter is in the ECU, you cant take it out physically, u have to bypass it or disconnect the sensor, which is not great to do. When u reach a certain speed, the ECU says thats enuf and cuts ur fuel.
post Jul 28, 2003 - 2:39 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
cutting it will cause a check engine light when traveling at high speeds for a few minutes.
its something i would put a switch on, so that i could disable it when i feel like trying to go faster than 115.
btw gt's do no have a speed limiter
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jul 28, 2003 - 2:56 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
No kidding, at the dyno the mechanic said he couldn't get my car past 100, but I think that's because OD was off, and it was pushing 3rd pretty hard. Or maybe my car is messed up, I hope not.
post Jul 28, 2003 - 3:28 PM
Mynzeyes
From Franklin/Nashville, TN
you could unplug the speed sensor. that would um, not allow the ECU to know how fast you're going...buuuut, as someone else mentioned, if you really wanna do this, then it'd be best to just put a switch somewhere in the line. smile.gif.
-John-
AIM==Mynzeyes
post Jul 28, 2003 - 3:51 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
Wouldn't you get mad cels?
post Jul 28, 2003 - 4:46 PM
Mynzeyes
QUOTE (HyperDeathKill @ Jul 28, 2003 - 3:05 PM)
:shrug:
but um, if you wanna do somethin like this, there's always that chance. sooo, i'd just plan on gettin a CEL. smile.gif
-John-
AIM==Mynzeyes
post Jul 28, 2003 - 9:56 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (HyperDeathKill @ Jul 28, 2003 - 12:10 PM)
with the OD that car will not go past 100mph. i accidentally hit the OD button while going 105mph and the rpms shout up to about 300-400 past redline and was hitting the revlimiter.
cool indy car sound, scarry as hell feeling.
as for the speed limiter, you have a GT, dont worry about it, seeing as how you dont have one.
but many ST's have one, i would not recomend disabling the speed sensor with auto trannies since the ecu controls them based on speed, if youy want to do it, you would need a switch, and only hit the switch when you are well into 4th gear.
Lo-Fi Version Time is now: August 26th, 2026 - 12:13 PM
