> How do I fix a dent and a scratch
post Jun 12, 2007 - 12:10 AM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
Just but this Celica, has about a foot by foot dent in the front left fender, to the left of the wheel, how can i get this dent out? I'd rather not buy and paint a replacement. Also, how do I fix a bad scratch with some rust on it. I can get pics up asap. Other than that, this car is decent tongue.gif
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
Replies (1 - 11)
post Jun 12, 2007 - 12:26 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
drill a hole and use a "t" shaped bolt inside on your fenders and pull!!!.....it worked on mines..... wink.gif
with the rust, get some of those rust-removers n sand away.....bondo it n paint.....
This post has been edited by DeW_H0e_GT: Jun 12, 2007 - 12:27 AM
post Jun 12, 2007 - 12:27 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
post a photo, depending on what it is, there is a think called "pops a dent" or somethign, it uses suction to pull out dents, if its not to bad that could work, and u wont have to drill nething.
if u post a photo, i could tell u if its a possibility.
Kawi Love
post Jun 12, 2007 - 12:41 AM
CelicaST_CALI
Joined Feb 28, '07
From Banland
wait then once u drill a hole in it u dont have a dent but u have a hole instead..
BANNED. for life, you moron.
post Jun 12, 2007 - 12:42 AM
devilsden97
Joined Jun 13, '05
QUOTE(CelicaST_CALI @ Jun 12, 2007 - 1:41 AM) [snapback]567483[/snapback]
bondo....dents are pretty serious buisness depending how big they are.
Kawi Love
post Jun 12, 2007 - 12:57 AM
CelicaST_CALI
Joined Feb 28, '07
From Banland
ok my car has lil dents all over and one big one on the passenger side door.Im pretty sure i can pop all the lil ones out but the door is just about the whole door panel.Is there anyway to pop that out or do i have to buy a new panel?If i have to buy a new panel where do i getone,toyota dealership?
post Jun 12, 2007 - 7:01 AM
DSToyo
Joined Dec 16, '06
From Maryland
QUOTE(CelicaST_CALI @ Jun 12, 2007 - 1:57 AM) [snapback]567491[/snapback]
the little dents all over the car, you most likely don't pull, just grind it down to bare metal, bondo it, the primer it. as for the door, i would get a new panel going from what you said. you can probably get one at the dealer, but i would start at a junkyard, it'll be much cheaper wink.gif
post Jun 17, 2007 - 9:45 PM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
do not drill a hole in your fender unless you are doing to weld it back up and put corrosion protection on the back. if you leave the hole and put filler (bondo) over it w/o welding it up it will wick moisture, rust UNDER the paint, the filler will fall off along with the paint.....try using a plunger on the dent if there are no creases or lines, if that doesnt work and you want to get brave, take the fender off the car and use a hammer to massage the metal back into place. use a hammer with a convex head..not a CLAW HAMMER or else you might as well toss it and get another fender. if you're scared of doing the hammer work, try the plunger a few times, try hitting it from the back with your palm, and if that doesn't work well, buy a fender and practice on the damaged one
Coming in 2010
post Jun 17, 2007 - 9:58 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
i used a rubber mallet and a screwdriver. put the hard end of the screwdriver to the outer most part of the dent and hit it with mallet/hammer on the outer edges towards teh middle of the dent until it is not visible on the inside. it may be noticeable on teh outside still just until you sand/prime/paint it. thats what i did.
post Jun 20, 2007 - 6:45 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
ok well i can probly find a whole new front in teh junkyards..we have a lot in north california! smile.gif
post Jun 20, 2007 - 10:28 PM
b1gr3d
Joined Feb 25, '03
actually i have heard from a few old timers that if you heat up the dents with a small butane torch then dowse it with some dry ice the small hail damage will pop out....do not burn your paint or else it's useless. and yes it will probably work
Coming in 2010
post Jun 22, 2007 - 7:12 PM
Jared95
Joined Apr 24, '07
From lufkin tx
QUOTE(b1gr3d @ Jun 21, 2007 - 3:28 AM) [snapback]570734[/snapback]
acually i just got done talking to a hail and dent repair guy who is very good at what he does and i asked him about the heat and cold treatment....he said its a myth it does work to a certain extent but it will not pop it out perfect.
Lo-Fi Version Time is now: August 23rd, 2026 - 11:04 PM
