> Rear Pass wheel area is smokin !!
post Jun 12, 2007 - 8:22 PM
Remy
Joined Jan 25, '06
From MN
Hey guys this morning I was going to work I took the highway then exited off and came to a stop then noticed the passenger rear wheel area was smoking !? It looked like I did a burnout !! But I know our cars aren't RWD, their wasn't a good spot to pull over and I was running late to work so after work I came home and took the wheel off inspected everything looked normal even had a friend come check it out everything was normal. But I noticed it had that burnt rubber smell you guys know what I'm talking about.....any clue what that was ?? And I was going maybe 60mph on the highway. Also when I took the lug nuts off it burnt my hand @#$% !!!!!
"To Protect And To Serve The Wealthy" -POLICE
post Jun 12, 2007 - 8:40 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
has your car been braking funny lately or making noises?
post Jun 12, 2007 - 9:31 PM
Hanyo
Joined Aug 16, '03
From Bay area
it can either of two things.
1) rear bearing is dead. So its dragging causing the heat.
2) brake caliper frozen and rubbing against the disk the entire time..
have you tried to spin the wheel by hand, see if it rotates freely?
post Jun 12, 2007 - 9:54 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(LewFX @ Jun 12, 2007 - 8:40 PM) [snapback]567822[/snapback]
Nope no weird noises.
QUOTE(Hanyo @ Jun 12, 2007 - 9:31 PM) [snapback]567837[/snapback]
1. Bearing is still good.
2. Took out my brakes and inspected the discs all normal. (could use new brake pads though)
You know what the weird thing is....this happened at the same stop yesterday too but I didn't notice any smoke just the smell....though it was someone else but I guess it was me... laugh.gif
post Jun 15, 2007 - 12:35 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check your ebrake cable
post Jun 15, 2007 - 8:18 AM
azian_advanced
Joined Apr 18, '05
From Calgary
probably your caliper pistons are getting stuck. i had the same problem before on my driver-side rear. there was smoke coming out of the wheel and it smelt like burning asphalt or something...
post Jun 15, 2007 - 6:31 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(rjbibeau @ Jun 15, 2007 - 12:35 AM) [snapback]568722[/snapback]
My ebrake cable is good I might need new shoes though.
QUOTE(azian_advanced @ Jun 15, 2007 - 8:18 AM) [snapback]568778[/snapback]
Yes !! I think thats the problem today coming from work I felt like rear pass wheel was saggin my car down it did feel like the brakes or caliper locked up on me everytime I come to a stop then once I hit the gas it releases. How did you fix your problem just new calipers ?? I checked my brake pads too they cracked on me, damn autozone lol last me 2 months. But I knew my pads wouldn't last I just bought them because I needed some pads FAST !! biggrin.gif
List to do
1. New pads
2. New rotors
3. New brake fluid
4. New caliper ??
5. Other misc brake stuff
post Jun 16, 2007 - 2:27 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i'd say try lubricating the inside of the caliper piston.. i would use 'white grease'. it's this aerosol spray with a thin straw on the spray nozzle (kinda like WD40) only it's thicker and would last longer than WD40. basically get the straw under the rubber seal of the piston walls and spray... then repeatedly press the brake pedal to get the caliper out and push it back in with a C-Clamp to get the 'white grease' or WD40 everywhere all around the piston walls..
if that doesn't fix the smoking brake pad problem.. then your calipers are probably ceased..
i'm not sure if i'm right on this one, but does anybody have anything better to suggest?
This post has been edited by azian_advanced: Jun 16, 2007 - 2:29 AM
post Jun 16, 2007 - 4:39 PM
Remy
Joined Jan 25, '06
From MN
Lo-Fi Version Time is now: August 1st, 2026 - 9:35 AM
