Jun 14, 2007 - 2:40 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Finally put my car back together after adding cruise control. However, my ABS light now stays on.
I've tried jumping E1 to Tc and removing the shorting pin while the key is in the IGN position. However, the orange ABS light stays on and the red airbag light then flashes constantly. Does this suggest a faulty ABS module or something else? I've started to check the wiring again, but there is nothing obvious causing the light to illuminate. This post has been edited by BloodyStupidDavey: Jun 14, 2007 - 3:16 PM -------------------- Davey
Items for sale |
Jun 14, 2007 - 3:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
my abs light is always on too, idk why tho. this will help me also
Jun 22, 2007 - 5:16 AM
![]() Enthusiast ![]() Joined Sep 9, '04 From England Currently Offline Reputation: 0 (0%) |
atleast u have the abs light on, mine hasnt worked in months ;/
Jul 4, 2007 - 4:00 PM
Enthusiast Joined Sep 7, '05 From Ensenada, Baja California, Mexico Currently Offline Reputation: 0 (0%) |
Did you check sensors on the wheels?, need to be clean, just clean, and maybe light goes off, also when you brake you did you heard a not normal noise or vibration?
Check those details. This post has been edited by tceligt: Jul 4, 2007 - 4:01 PM |
Apr 14, 2009 - 5:18 PM
![]() Enthusiast Joined Aug 8, '07 From uk Currently Offline Reputation: 0 (0%) |
im having the same problem as this....
I've tried jumping E1 to Tc and removing the shorting pin while the key is in the IGN position. However, the orange ABS light stays on and the red airbag light then flashes constantly. why wont it just give me the codes as to whats up with the abs? really need to get this sorted as its failed its MOT because the abs light is on. |
Apr 14, 2009 - 5:33 PM
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Did you check sensors on the wheels?, need to be clean, just clean, and maybe light goes off, also when you brake you did you heard a not normal noise or vibration? Check those details. X2 and the sensor needs to be quite tight on there, no wobbles this will set the light off too,. i had this problem after wheelbearing turned out the sensor just needed cleaning and tightening |
Apr 15, 2009 - 4:27 PM
my sensors are firmly on tried to get one off the other day and found it almost impossible.
im sure i read somewhere that the airbag flashing means voltage drop or no codes. there was no more info an it just left me confused i really need to get this sorted as my car is off the road while ive no MOT |
| Lo-Fi Version | Time is now: May 9th, 2026 - 9:19 AM |
