Jun 17, 2007 - 6:08 PM
Enthusiast ![]() Joined Oct 8, '06 From Jersey sHore PA Currently Offline Reputation: 0 (0%) |
ok so my car wont start and i see the check engine light on, so i used a paper clip to jump te1 and e1(i think there the right ones) well anyway i turned the key and my check engine light was blinking continuously, what code is that
-------------------- 3sgte next year i hope
Jun 18, 2007 - 4:29 PM
ok so i pulled out all of the fuses and relays and waited, then i put them back in, then i jumped te1 and e1 and my check engine light blinks 1 time then pauses and then blinks 2 times, is that a code 12, whats a code 12, btw my engine wont even turn over
This post has been edited by slow94st: Jun 18, 2007 - 4:31 PM -------------------- 3sgte next year i hope
Jun 18, 2007 - 11:43 PM
Jun 19, 2007 - 11:31 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
Code Blink Circuit
n/a 8 flashes normal 12 1, then 2 G, NE signal (#1) 13 1, then 3 G, NE signal (#2) 14 1, then 4 Ignition Signal Circuit 16 1, then 5 A/T Control Signal 21 2, then 1 Oxygen Sensor Signal 22 2, then 2 Engine coolent Temp Sensor Signal 24 2, then 4 Intake Air Temperature Sensor 25 2, then 5 Air/Fuel Ratio Lean Malfunction 26 2, then 6 Air/Fuel Ratio Rich Malfunction 27 2, then 7 Sub-Oxygen Sensor signal 31 3, then 1 MAP sensor 41 4, then 1 Throttle Position Sensor signal 42 4, then 2 Speed Sensor Signal 43 4, then 3 Starter Signal 51 5, then 1 Switch condition signal 52 5, then 2 Knock Sensor 71 7, then 1 EGR System This post has been edited by Jaws4God: Jun 19, 2007 - 11:31 AM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jun 19, 2007 - 11:57 AM
so how is the code 12 not making my car turn over
Jun 19, 2007 - 12:18 PM
I should of explained it, sorry.
It's the ignition/distributor that's the problem, check you distributor cap/rotor and make sure they're not bad, also the wires, plugs. worse case senerio, it's the timing belt. To check this, take the dizzy cap off so you can see the rotor. Then have someone try to start the car and you will be looking at the rotor, if it doesn't spin when someone is trying to start the car, you have a problem. -------------------- |
Jun 19, 2007 - 12:52 PM
the starter dosent even turn
Jun 19, 2007 - 1:52 PM
when you turn the key, does anything happen ? what sound...
Jun 19, 2007 - 2:26 PM
well when i push in the clutch and turn the key it just makes like a click sound like a relay or somthing would make
Jun 19, 2007 - 4:52 PM
then it's your starter...
Jun 19, 2007 - 4:59 PM
****, man it just started 2 weeks ago than it sat there, i just replased that starter 2, i think it was used
Jun 19, 2007 - 5:03 PM
try to pop start it or tap on the starter with a hammer, it might start then.
Jun 19, 2007 - 6:49 PM
ya me and my dad tryed to pop start it in 1,2,3 gear but it didnt. i dont think it was movin fast enough, i did hit the starter but when it wasnt cranking when i hit it
Jun 19, 2007 - 9:56 PM
will a starter out of a 5th gen 5sfe work, my buddy has one
Jun 19, 2007 - 9:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
QUOTE(slow94st @ Jun 19, 2007 - 7:49 PM) [snapback]570176[/snapback] ya me and my dad tryed to pop start it in 1,2,3 gear but it didnt. try again....and make sure u go pretty fast...let the clutch in REALLY easy and slow. QUOTE(slow94st @ Jun 19, 2007 - 10:56 PM) [snapback]570227[/snapback] will a starter out of a 5th gen 5sfe work, my buddy has one should work but if it didnt start by rolling it, i think u have a bigger issue then a starter. -------------------- ![]() Kawi Love |
Jun 19, 2007 - 10:00 PM
why do i have to let it out slow
Jun 19, 2007 - 10:04 PM
QUOTE(slow94st @ Jun 19, 2007 - 11:00 PM) [snapback]570231[/snapback] why do i have to let it out slow cuz the car will bairly be moving.... its like going from a stand still. U have to give the engine some gas to get the rpm up to overcome the inertia of the stationary car, and the friction between the tires and the road. If the car is rolling at <5mph u need to put the clutch in VERY softly, and easy, so that it will catch and the cars inertia will be transfered to the flywheel and then to the crank then to the pistons then combustion and the car SHOULD start. its a very hard trick to do...but its one of the perks of driving stick...u can ALWAYS start it. -------------------- ![]() Kawi Love |
Jun 19, 2007 - 10:20 PM
i was letting it out fast, i need a big hill, 2maro im goin to advanceauto parts and im takin my starters and have them put them on the machine and test both of them
This post has been edited by slow94st: Jun 19, 2007 - 10:32 PM -------------------- 3sgte next year i hope
Jun 20, 2007 - 6:15 PM
gt starters dont work in st's, i took my starters to advance auto parts and found out both of my starters are bad so i am going to pick a new one up 2maro $103 jeez
| Lo-Fi Version | Time is now: July 30th, 2026 - 2:06 AM |
