Jun 20, 2007 - 1:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
what could this be from? my oil does need to be changed. I guess i should look at the plugs right? compression test maybe???? i dont exactly know what i should start off with? any advice? i have a 255 wabrol pump, stock injectors and stock plugs and im running 91 octane. please shed some light? so i know its not knock now but something else. It seems to be wired correctly but still when im at boost the green led does not stay on. instead the red and green led flash. and when my key is turned to acc. the green light is full brightness and the red is half. for all you who have done the mod when the key is in the acc position what light is on? i dont get why both are on the ecu and its tcp line must be crazy. does it matter that i got my ground for the red led and power for the green led from the plug for the cig lighter????? perhaps maybe the current is to strong i dont knowalfhdlhfaldfhj This post has been edited by urbandork: Jun 21, 2007 - 3:47 PM |
Jun 20, 2007 - 1:24 PM
it means that you didnt solder your wires correctly.
Jun 20, 2007 - 1:58 PM
ill have to double check but im pretty sure i got all the wires done correctly.
the red from the red led and black from the green led reads off the ecu tpc wire and the black from the red goes to ground and the red from the green goes to power. isnt that how its suppose to be???? i figured if i did it wrong one of the lights wouldnt light up right? and why else would the green and red LED's flash back and forth??? plus if there is really knock the light is supose to stay red for a little while right This post has been edited by urbandork: Jun 21, 2007 - 3:49 PM |
Jun 20, 2007 - 7:59 PM
these are not really monitoring the knock sensor. so you would never have it blink ever time you knocked or anything like that. the idea is that they will tell you when the ecu is in safe mode. once it goes into safe mode, it will stay there for at least a few min.
here is a wiring diagram on how to set this up. ![]() it is also totally possible that this mod does not work correctly on a 3rd gen motor. ive never tried it, so i dont know for sure. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 20, 2007 - 10:32 PM
damn so i checked the wiring and its jsut as its supose to be.
i tried to only connect the green led and it still blinked then i tried only the red led and it still blinked when i have the key turned to acc. both the green and the red light up but the red led isnt as bright. Then if i disconnect the ground line on the red led which is conncted to the ground from the cig lit. plug the red led turns off and the green stays on..... why would the red led be on anyway?????? omg so frustrated... and i cut that damn plastic peice so the evc wouldnt be centered so i could put the leds next to it... any advice? has any one with a 3rd gen tried this mod??? |
Jun 20, 2007 - 10:42 PM
are you sure you connected the RED wire from the green led, directly to the Black wire from the green led....and then run a single wire to the ecu?
also, how did you figure out what pin to use on your 3rd gen ecu? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 21, 2007 - 2:50 AM
QUOTE(lagos @ Jun 21, 2007 - 3:42 AM) [snapback]570739[/snapback] are you sure you connected the RED wire from the green led, directly to the Black wire from the green led....and then run a single wire to the ecu? also, how did you figure out what pin to use on your 3rd gen ecu? was that supose to read.... are you sure you DIDNT connect the red wire from the green led directly to the black wire from the RED led and then run the black wire from the green led and the red wire from the red led to the signal wire to the ecu. Cus thats now how ur diagram looks to be. I double checked the wiring and its exactly how it shows on the diagram im using the ground and 12v suplly from the cig lighter plug (not the plug for the lighted ring of the cig lighter) what i really dont get is why when i have the key turned to acc. both lights are on. the green being fully lit and the red only looking half bright. When im off boost the red led is on but when im on boost the green and red blink in opposite of eachother. its like the ecu line is changing poles all the time. the TCP line should light up the red led no matter what sets it in safe mode right? cus im thinking about unpluging the level sensor for the IC to get it to put it in safe mode. what do you think about doing this.... jsut to see what the tcp does |
Jun 21, 2007 - 11:29 AM
now im getting confused. ...
you take the power wire from the red led, and the ground wire from the green led and join them togher. then run a single wire to the ecu. so you should have a Y connection. then for the other 2 wires, you find any 12v source for the positive wire and any good ground for the negative. check your email ... im sending you a vid of how it should work while driving. This post has been edited by lagos: Jun 21, 2007 - 11:35 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 21, 2007 - 1:53 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Now I am curious.
QUOTE(lagos @ Jun 21, 2007 - 5:29 PM) [snapback]570891[/snapback] check your email ... im sending you a vid of how it should work while driving. Ooh, vid! Any chance you cold pop it on YouTube or Google and paste the link here? -------------------- Davey
Items for sale |
Jun 21, 2007 - 3:26 PM
i know how it should look but it doesnt do that.
I pulled the plug for the level sensor on my IC so it would put me in safe mode and the red led stays red all the time. so i know its working when i have no cel and the plug is back in i still am getting the red and green led flashing on and off from eachother. akjdfjzldfjdsal;f;df y isnt this working i have the y connection just like it supose to be and im running the other wires jsut as they are supose to be. I dont get it. this is frustrating. Im begining to think that theres something else rong with my car or ecu and that theres actually a reason why the tcp line is constantly chaing poles when under boost. is there any reason for the vsv for the turbo to flick back and forth from normal to non normal while boosting. |
Jun 21, 2007 - 5:46 PM
ok so i took another look at the wiring today and took some pix.
im getting the tvsv/tcp signal for my turbo off of pin 2 on the largest plug which is C. This was found via the EWD for the st205 and backed up via other pitures on line the line can be seen here and its the blue with red line and im tapping/teeing in about and inch after the plug ![]() i have my LED's hooked up like this (see pic) with the + from the red LED and the - from the green LED soldered together with the white wire which is tapped into the blue w/red line wire off the ecu plug in the first pic. The - and + from the red and green led, respectivly, are going to the ground and a 12v line which use to feed the CIG lighter. ![]() Thinking that radioshack may have messed up on the wiring of the resistor or something i tested it out. BOTH led's when hooked up to a ground an 12v line WILL only work with the red wire to power and the black wire to ground. While taking everything apart to rewire i noticed that with the wires hooked up like they are in the above picture and the key turned to ACC both lights lit up. The red one only being half as intence as the green one. BUUUUTTT when i took off the signal line both light up equally as bright. I have a piture below to explain what this looked like ![]() So whats wrong here?????? why is it when the LED's are hooked up @$$ backwards and powered they work?????? they dont work like batteries do they??? . . . . . . . So after being stumped as to why both LED's light up when wired up backwards like that i thought it might be smart just to wire ONE color LED to the signal line. I chose the GREEN led. the TCP singal line wired to the green led's black wire and the red wire to the 12v powero line for the cig lighter....... i took it for a test drive and guess what????? the DAMN green LED still blinks on and off just as it had before. THIS MEANS that it must be my ECU's TCP signal wire right?????? but why would the TCP line osilate polarities between neg. and pos. |
Jun 21, 2007 - 8:37 PM
do you have your tvsv pluged into the factory harness?
Jun 21, 2007 - 10:27 PM
QUOTE(lagos @ Jun 22, 2007 - 1:37 AM) [snapback]571076[/snapback] do you have your tvsv pluged into the factory harness? what do you mean? im pretty sure the answer is yes as i pulled the factory harness out of the clip intached and it all went in the way it came out. do you mean the wire labled "vsv (for turbo pressure)" on the EWD? cus thats still pluged in all i did was T into that as its the TPC on the ECU. what what do you mean by the tvsv plug???? do you know what plug number it is or where it would be? and what it looks like? This post has been edited by urbandork: Jun 21, 2007 - 10:29 PM |
Jun 22, 2007 - 12:09 AM
im talking about the actual tvsv unit thats is bolted to the block. if you forgot to plug that in, the led wont work.
you soldered your connections, right? no crimping or anything that could have come loose? you should test that ecu wire with a multimeter as you cycle the key from off to acc and on. you should see it giving 12v and then turning into a ground as you cycle the key. if all that doesnt help, then i would guess they changed something on the 3rd gen ecu. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 22, 2007 - 12:21 AM
can you link me to any 3rd gen wiring diagrams you were looking at? i dont have any on my pc for the 3rd gen motor.
i did have one really hard to read pinout jpg. it showed tpc to be the 2nd pin from the top, top row going from left to right. i think MAYBE you got the wrong wire... you might have taped into one of the wires that goes to your injectors (no wonder they are pulsating/blinking). but again, i dont have a real diagram to look at to know for sure. This post has been edited by lagos: Jun 22, 2007 - 12:25 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 22, 2007 - 1:02 AM
QUOTE(lagos @ Jun 22, 2007 - 5:21 AM) [snapback]571184[/snapback] can you link me to any 3rd gen wiring diagrams you were looking at? i dont have any on my pc for the 3rd gen motor. i did have one really hard to read pinout jpg. it showed tpc to be the 2nd pin from the top, top row going from left to right. i think MAYBE you got the wrong wire... you might have taped into one of the wires that goes to your injectors (no wonder they are pulsating/blinking). but again, i dont have a real diagram to look at to know for sure. im using the EWD from the st205 repair manuel. I know its not the injector wire cus while those are on the same plug E10 C the wires are c24 injector 4 black yellow wire, c25 injector 3 black red wire, c11 injector 2 black white wire, c12 injector one black blue wire the EDW clearly says the TPC is wire 2 on plug e10C/big plug and that its a blue red wire. where exactly is the TVSV unit you speak of? and does it have a plug?? what does it look like? where on the block is it? thanks for all the help? do u know of anyone with this mod on a 3rd gen? would you be able to ask on celica tech cus i still cant post there. damn i forgot lol .......... i dont remember where i DLed the repair manual for the st205 but i have it saved so if u want it let me know i can email it to you. This post has been edited by urbandork: Jun 22, 2007 - 1:03 AM |
Jun 22, 2007 - 4:52 AM
QUOTE(urbandork @ Jun 22, 2007 - 7:02 AM) [snapback]571191[/snapback] im using the EWD from the st205 repair manuel. I know its not the injector wire cus while those are on the same plug E10 C the wires are c24 injector 4 black yellow wire, c25 injector 3 black red wire, c11 injector 2 black white wire, c12 injector one black blue wire the EDW clearly says the TPC is wire 2 on plug e10C/big plug and that its a blue red wire. I am not sure this is right. You are trying to monitor the knock sensor, right? TPC is the turbo pressure (boost) meter output from the ECU. This is a mark-space signal intended to drive analogue or digital dials/gauges. The ratio of mark (+12v) to space (0v) indicates the level. Which explains what you are seeing with the red and blue LEDs. I am not familiar with this mod, but if you want to monitor the knock sensor, it is on pin A13 and is a white wire. If you want to tap into this, it is important that you use shielded (coax) wire to do so. -------------------- Davey
Items for sale |
Jun 22, 2007 - 11:04 AM
can someone post an st205 wiring diagram?
Jun 22, 2007 - 12:07 PM
QUOTE(lagos @ Jun 22, 2007 - 4:04 PM) [snapback]571261[/snapback] can someone post an st205 wiring diagram? the one i have is a good amount of pages i can email it to you. |
Jun 22, 2007 - 1:07 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(BloodyStupidDavey @ Jun 22, 2007 - 2:52 AM) [snapback]571216[/snapback] I am not sure this is right. You are trying to monitor the knock sensor, right? TPC is the turbo pressure (boost) meter output from the ECU. This is a mark-space signal intended to drive analogue or digital dials/gauges. The ratio of mark (+12v) to space (0v) indicates the level. Which explains what you are seeing with the red and blue LEDs. That's not quite what this mod is doing. He is monitoring the Turbo Pressure VSV output from the ECU to see if the ECU is 'happy' - meaning no knock, appropriate temps and no check engine lights. The signal doesn't switch quickly and should be constantly red, or switching from red to green on boost transitions. This part of the ECU control is the same (or very very similar) to the gen2 motor/ecu.I am not familiar with this mod, but if you want to monitor the knock sensor, it is on pin A13 and is a white wire. If you want to tap into this, it is important that you use shielded (coax) wire to do so. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
| Lo-Fi Version | Time is now: July 29th, 2026 - 2:31 AM |
