> LED TVSV mod not working alkdfjaldfj, green red flash at boost.
post Jun 20, 2007 - 1:21 PM
urbandork
Joined Jul 16, '04
From Los Angeles
ok so after installing the LED knock light mod i have found that at any boost level my red and green led flicker on and off rather then just the green staying on. I assume this means i have knock in one cylinder and each time that cylinder fires my knock sensor picks it up and thus my green and red light blink on and off.
what could this be from? my oil does need to be changed. I guess i should look at the plugs right? compression test maybe????
i dont exactly know what i should start off with?
any advice?
i have a 255 wabrol pump, stock injectors and stock plugs and im running 91 octane.
please shed some light?
so i know its not knock now but something else. It seems to be wired correctly but still when im at boost the green led does not stay on. instead the red and green led flash.
and when my key is turned to acc. the green light is full brightness and the red is half.
for all you who have done the mod when the key is in the acc position what light is on?
i dont get why both are on the ecu and its tcp line must be crazy.
does it matter that i got my ground for the red led and power for the green led from the plug for the cig lighter????? perhaps maybe the current is to strong i dont knowalfhdlhfaldfhj
This post has been edited by urbandork: Jun 21, 2007 - 3:47 PM
- urbandork   LED TVSV mod not working alkdfjaldfj   Jun 20, 2007 - 1:21 PM
- - lagos   it means that you didnt solder your wires correctl...   Jun 20, 2007 - 1:24 PM
- - urbandork   ill have to double check but im pretty sure i got ...   Jun 20, 2007 - 1:58 PM
- - lagos   these are not really monitoring the knock sensor. ...   Jun 20, 2007 - 7:59 PM
- - urbandork   damn so i checked the wiring and its jsut as its s...   Jun 20, 2007 - 10:32 PM
- - lagos   are you sure you connected the RED wire from the g...   Jun 20, 2007 - 10:42 PM
|- - urbandork   QUOTE(lagos @ Jun 21, 2007 - 3:42 AM...   Jun 21, 2007 - 2:50 AM
- - lagos   now im getting confused. ... you take the power ...   Jun 21, 2007 - 11:29 AM
|- - BloodyStupidDavey   Now I am curious. QUOTE(lagos @ Jun 21, 2007...   Jun 21, 2007 - 1:53 PM
- - urbandork   i know how it should look but it doesnt do that. ...   Jun 21, 2007 - 3:26 PM
- - urbandork   ok so i took another look at the wiring today and ...   Jun 21, 2007 - 5:46 PM
|- - phattyduck   QUOTE(urbandork @ Jun 21, 2007 - 3:4...   Jun 22, 2007 - 1:11 PM
- - lagos   do you have your tvsv pluged into the factory harn...   Jun 21, 2007 - 8:37 PM
|- - urbandork   QUOTE(lagos @ Jun 22, 2007 - 1:37 AM...   Jun 21, 2007 - 10:27 PM
- - lagos   im talking about the actual tvsv unit thats is bol...   Jun 22, 2007 - 12:09 AM
- - lagos   can you link me to any 3rd gen wiring diagrams you...   Jun 22, 2007 - 12:21 AM
|- - urbandork   QUOTE(lagos @ Jun 22, 2007 - 5:21 AM...   Jun 22, 2007 - 1:02 AM
|- - BloodyStupidDavey   QUOTE(urbandork @ Jun 22, 2007 - 7:0...   Jun 22, 2007 - 4:52 AM
|- - phattyduck   QUOTE(BloodyStupidDavey @ Jun 22, 2007 ...   Jun 22, 2007 - 1:07 PM
|- - urbandork   QUOTE(phattyduck @ Jun 22, 2007 - 6...   Jun 22, 2007 - 2:05 PM
|- - phattyduck   QUOTE(urbandork @ Jun 22, 2007 - 12...   Jun 22, 2007 - 3:37 PM
|- - urbandork   QUOTE(phattyduck @ Jun 22, 2007 - 8...   Jun 22, 2007 - 4:10 PM
- - lagos   can someone post an st205 wiring diagram?   Jun 22, 2007 - 11:04 AM
|- - urbandork   QUOTE(lagos @ Jun 22, 2007 - 4:04 PM...   Jun 22, 2007 - 12:07 PM
- - urbandork   yeah but i soldered a line shortly after the pic w...   Jun 22, 2007 - 2:00 PM
- - WannabeGT4   The red LED is dimmer because the VSV's coil i...   Jun 23, 2007 - 7:15 AM
- - urbandork   could this be true????? any one want to comment?   Jun 25, 2007 - 12:38 PM
- - lagos   SOMEONE POST THE WIRING DIAGRAMS FOR A 3RD GEN...   Jun 25, 2007 - 1:02 PM
|- - phattyduck   QUOTE(lagos @ Jun 25, 2007 - 11:02 A...   Jun 25, 2007 - 4:06 PM
- - WannabeGT4   I'll try to post links to the manuals tonight....   Jun 25, 2007 - 1:45 PM
- - phattyduck   Found some diagrams on my compy: Nothing ...   Jun 25, 2007 - 4:11 PM
- - WannabeGT4   Here are the ST205 BGBs... Should be the same thin...   Jun 25, 2007 - 6:08 PM
- - lagos   finally ... ive been wanting a 205 bgb for a while...   Jun 25, 2007 - 10:32 PM
- - urbandork   any verdict?   Jun 26, 2007 - 1:11 PM
- - lagos   this mod does not work correctly with a 3rd gen.   Jun 26, 2007 - 4:20 PM
|- - phattyduck   QUOTE(lagos @ Jun 26, 2007 - 2:20 PM...   Jun 27, 2007 - 1:51 PM
- - WannabeGT4   I say it works... just a little differently. Urban...   Jun 27, 2007 - 5:05 PM
|- - BloodyStupidDavey   QUOTE(WannabeGT4 @ Jun 27, 2007 - 11...   Jun 27, 2007 - 5:35 PM
|- - urbandork   QUOTE(BloodyStupidDavey @ Jun 27, 2007 ...   Jun 27, 2007 - 5:42 PM
|- - phattyduck   QUOTE(urbandork @ Jun 27, 2007 - 3:4...   Jun 27, 2007 - 6:03 PM
- - lagos   QUOTE(BloodyStupidDavey @ Jun 27, 2007 ...   Jun 27, 2007 - 6:18 PM
Lo-Fi Version Time is now: September 12th, 2026 - 12:40 PM
