Jun 20, 2007 - 1:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
what could this be from? my oil does need to be changed. I guess i should look at the plugs right? compression test maybe???? i dont exactly know what i should start off with? any advice? i have a 255 wabrol pump, stock injectors and stock plugs and im running 91 octane. please shed some light? so i know its not knock now but something else. It seems to be wired correctly but still when im at boost the green led does not stay on. instead the red and green led flash. and when my key is turned to acc. the green light is full brightness and the red is half. for all you who have done the mod when the key is in the acc position what light is on? i dont get why both are on the ecu and its tcp line must be crazy. does it matter that i got my ground for the red led and power for the green led from the plug for the cig lighter????? perhaps maybe the current is to strong i dont knowalfhdlhfaldfhj This post has been edited by urbandork: Jun 21, 2007 - 3:47 PM |
urbandork LED TVSV mod not working alkdfjaldfj Jun 20, 2007 - 1:21 PM
lagos it means that you didnt solder your wires correctl... Jun 20, 2007 - 1:24 PM
urbandork ill have to double check but im pretty sure i got ... Jun 20, 2007 - 1:58 PM
lagos these are not really monitoring the knock sensor. ... Jun 20, 2007 - 7:59 PM
urbandork damn so i checked the wiring and its jsut as its s... Jun 20, 2007 - 10:32 PM
lagos are you sure you connected the RED wire from the g... Jun 20, 2007 - 10:42 PM
urbandork QUOTE(lagos @ Jun 21, 2007 - 3:42 AM... Jun 21, 2007 - 2:50 AM
lagos now im getting confused. ...
you take the power ... Jun 21, 2007 - 11:29 AM
BloodyStupidDavey Now I am curious.
QUOTE(lagos @ Jun 21, 2007... Jun 21, 2007 - 1:53 PM
urbandork i know how it should look but it doesnt do that.
... Jun 21, 2007 - 3:26 PM
urbandork ok so i took another look at the wiring today and ... Jun 21, 2007 - 5:46 PM
phattyduck QUOTE(urbandork @ Jun 21, 2007 - 3:4... Jun 22, 2007 - 1:11 PM
lagos do you have your tvsv pluged into the factory harn... Jun 21, 2007 - 8:37 PM
urbandork QUOTE(lagos @ Jun 22, 2007 - 1:37 AM... Jun 21, 2007 - 10:27 PM
lagos im talking about the actual tvsv unit thats is bol... Jun 22, 2007 - 12:09 AM
lagos can you link me to any 3rd gen wiring diagrams you... Jun 22, 2007 - 12:21 AM
urbandork QUOTE(lagos @ Jun 22, 2007 - 5:21 AM... Jun 22, 2007 - 1:02 AM
BloodyStupidDavey QUOTE(urbandork @ Jun 22, 2007 - 7:0... Jun 22, 2007 - 4:52 AM
phattyduck QUOTE(BloodyStupidDavey @ Jun 22, 2007 ... Jun 22, 2007 - 1:07 PM
urbandork QUOTE(phattyduck @ Jun 22, 2007 - 6... Jun 22, 2007 - 2:05 PM
phattyduck QUOTE(urbandork @ Jun 22, 2007 - 12... Jun 22, 2007 - 3:37 PM
urbandork QUOTE(phattyduck @ Jun 22, 2007 - 8... Jun 22, 2007 - 4:10 PM
lagos can someone post an st205 wiring diagram? Jun 22, 2007 - 11:04 AM
urbandork QUOTE(lagos @ Jun 22, 2007 - 4:04 PM... Jun 22, 2007 - 12:07 PM
urbandork yeah but i soldered a line shortly after the pic w... Jun 22, 2007 - 2:00 PM
WannabeGT4 The red LED is dimmer because the VSV's coil i... Jun 23, 2007 - 7:15 AM
urbandork could this be true????? any one want to comment? Jun 25, 2007 - 12:38 PM
lagos SOMEONE POST THE WIRING DIAGRAMS FOR A 3RD GEN... Jun 25, 2007 - 1:02 PM
phattyduck QUOTE(lagos @ Jun 25, 2007 - 11:02 A... Jun 25, 2007 - 4:06 PM
WannabeGT4 I'll try to post links to the manuals tonight.... Jun 25, 2007 - 1:45 PM
phattyduck Found some diagrams on my compy:
Nothing ... Jun 25, 2007 - 4:11 PM
WannabeGT4 Here are the ST205 BGBs... Should be the same thin... Jun 25, 2007 - 6:08 PM
lagos finally ... ive been wanting a 205 bgb for a while... Jun 25, 2007 - 10:32 PM
urbandork any verdict? Jun 26, 2007 - 1:11 PM
lagos this mod does not work correctly with a 3rd gen. Jun 26, 2007 - 4:20 PM
phattyduck QUOTE(lagos @ Jun 26, 2007 - 2:20 PM... Jun 27, 2007 - 1:51 PM
WannabeGT4 I say it works... just a little differently. Urban... Jun 27, 2007 - 5:05 PM
BloodyStupidDavey QUOTE(WannabeGT4 @ Jun 27, 2007 - 11... Jun 27, 2007 - 5:35 PM
urbandork QUOTE(BloodyStupidDavey @ Jun 27, 2007 ... Jun 27, 2007 - 5:42 PM
phattyduck QUOTE(urbandork @ Jun 27, 2007 - 3:4... Jun 27, 2007 - 6:03 PM
lagos QUOTE(BloodyStupidDavey @ Jun 27, 2007 ... Jun 27, 2007 - 6:18 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:40 PM |
