Jun 23, 2007 - 5:27 AM
Enthusiast Joined Jul 29, '06 From BC, Canada Currently Offline Reputation: 0 (0%) |
Any diagnosis or advice would be greatly appreciated
So, i've noticed in the last 4 months or so that when I start my 94 ST, the car will puff out blue/white exhaust I would say once a week. It occurs randomly and I thought it might be because I had let it sit for a 2 days but like I said its random. No idea if its a big deal or not. This only happens once in a while on start-up and not while I am driving. Thanks |
Jun 23, 2007 - 10:01 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Blue smoke=burned oil
White smoke=Burned coolant If its only at start-up then you prob have bad valve seals which is normal wear-and-tear on cars. -------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 24, 2007 - 3:10 AM
QUOTE(Remy @ Jun 23, 2007 - 10:01 AM) [snapback]571552[/snapback] Blue smoke=burned oil White smoke=Burned coolant If its only at start-up then you prob have bad valve seals which is normal wear-and-tear on cars. thanks, any idea on cost of repair or do I even need to repair right away? This post has been edited by BC_Celi10: Jun 24, 2007 - 3:11 AM |
Jun 25, 2007 - 12:53 AM
QUOTE(BC_Celi10 @ Jun 24, 2007 - 3:10 AM) [snapback]571700[/snapback] QUOTE(Remy @ Jun 23, 2007 - 10:01 AM) [snapback]571552[/snapback] Blue smoke=burned oil White smoke=Burned coolant If its only at start-up then you prob have bad valve seals which is normal wear-and-tear on cars. thanks, any idea on cost of repair or do I even need to repair right away? Its noting to worry about unless it smokes bad when your driving it, before your next oil change add about half a bottle of ATF fluid into your oil, drive for 100-200 miles then change your oil immediately don't leave it in their too long it should reduce (smoke) or fix your valve seals problem, -------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 26, 2007 - 9:22 AM
Enthusiast ![]() Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
Valve stem seals require specialized tooling that can be purchased off ebay, I replaced mine while the head was still installed on car, it's a PITA though and time consuming. Search valve stem seal on this forum.
| Lo-Fi Version | Time is now: August 29th, 2026 - 4:28 PM |
