Jun 26, 2007 - 6:22 PM
If you havent been fallowing, my GF wants to buy a celica these days, and i actually just found a good deal on a 95 ST today. The car looks mint, but has high milage, almost 200xxxmiles. Any ways, i figure if the body is good, i can always swap motors. Since its an ST, i was thinkin a silvertop would b fun in it. I have alot of friends with AE's who have 20V motors sittin in the garage's with full wiring harness i could get for $500. My main question is, is there any fabrication work needed to swap a 20V into a 1.8's spot?? The harness conversion wont be a problem, but im just wondering if theres any thing needed to fabricate up to swap it in. Also, could i keep A/C with the swap too??
Jun 26, 2007 - 10:28 PM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
The only things that need to be refabbed is all of the power steering lines, a/c lines, and some of the vacuum lines. You'll also need to weld the 20v's downpipe to the celica's original downpipe where the the O2 sensor suppose to bolt on and a longer throttle cable from a paseo. Make sure to keep the the celica's original a/c idle up vsv thats mounted on the firewall, you'll need it to maintain idle when the a/c compressor's clutch kicks in. Without it the engine will stall out. As far as putting the engine in, it's a pretty much a direct drop in. Everything should line up accordingly.
This post has been edited by netrata: Jun 26, 2007 - 10:59 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 4:04 AM |
