> 2 bar map sensor
post Jul 4, 2007 - 9:37 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
ok im currently using check valves and im wondering what i have to do to put a 2 bar map sensor on just take out the map sensor and put the new one in and replace the check valves with regular vac hosing? and i have an safc 2 what do i need to change on it so my ecu isnt all screwed up? and if anyone has a link to somewhere i can buy one that would be great
BOOST GETS YOU LAID!!!!
- jesterwr217   2 bar map sensor   Jul 4, 2007 - 9:37 AM
- - Batman722   what size injectors are you running ?   Jul 4, 2007 - 10:02 AM
|- - jesterwr217   QUOTE(Batman722 @ Jul 4, 2007 - 11:0...   Jul 4, 2007 - 10:14 AM
- - presure2   yup, remove the check valves, install a straight s...   Jul 4, 2007 - 2:56 PM
|- - CaliJeff   QUOTE(presure2 @ Jul 4, 2007 - 12:56...   Jul 4, 2007 - 3:45 PM
|- - presure2   QUOTE(CaliJeff @ Jul 4, 2007 - 4:45 ...   Jul 4, 2007 - 5:14 PM
- - CaliJeff   KK.   Jul 4, 2007 - 5:32 PM
- - jesterwr217   what do i have to change on the safc 2   Jul 4, 2007 - 10:25 PM
- - Shocker   what are you using to tune this just your air fuel...   Jul 8, 2007 - 1:48 PM
|- - jesterwr217   QUOTE(Shocker @ Jul 8, 2007 - 2:48 P...   Jul 8, 2007 - 11:51 PM
- - Shocker   i want a widband.   Jul 9, 2007 - 7:16 PM
|- - jesterwr217   QUOTE(Shocker @ Jul 9, 2007 - 8:16 P...   Jul 9, 2007 - 8:07 PM
- - CaliJeff   off topic, for the air/fuel wideband; do u have to...   Jul 9, 2007 - 11:58 PM
|- - jesterwr217   QUOTE(CaliJeff @ Jul 10, 2007 - 12:5...   Jul 10, 2007 - 12:42 AM
- - jesterwr217   ok got the sensor today ill be putting it in tomor...   Jul 14, 2007 - 9:34 PM
|- - southwest2118   QUOTE(jesterwr217 @ Jul 14, 2007 - 8...   Jul 15, 2007 - 3:16 PM
- - jesterwr217   ok added nine to the fuel at low throttle does tha...   Jul 15, 2007 - 1:06 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 15, 2007 - 2...   Jul 15, 2007 - 1:45 PM
- - jesterwr217   im using the 2nd gen mr2 im just adjusting the fue...   Jul 15, 2007 - 3:49 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 15, 2007 - 4...   Jul 15, 2007 - 6:50 PM
|- - jesterwr217   QUOTE(presure2 @ Jul 15, 2007 - 7:50...   Jul 15, 2007 - 7:52 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 15, 2007 - 8...   Jul 15, 2007 - 9:22 PM
|- - jesterwr217   QUOTE(presure2 @ Jul 15, 2007 - 10:2...   Jul 15, 2007 - 10:47 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 15, 2007 - 11...   Jul 21, 2007 - 7:38 AM
|- - jesterwr217   QUOTE(presure2 @ Jul 21, 2007 - 8:38...   Jul 21, 2007 - 4:48 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 21, 2007 - 5...   Jul 22, 2007 - 7:27 AM
|- - jesterwr217   QUOTE(presure2 @ Jul 22, 2007 - 8:27...   Jul 22, 2007 - 2:06 PM
- - jesterwr217   is someone gonna help me with this prob or am i go...   Jul 18, 2007 - 9:16 PM
- - Celiracer18   his 7mgte injectors are 440cc's or atleast sho...   Jul 21, 2007 - 3:33 PM
- - Shocker   I too need help with this as i am about to install...   Jul 21, 2007 - 6:48 PM
- - Shocker   ive gotthe green top injectors and i cant get stoi...   Jul 22, 2007 - 8:51 PM
|- - presure2   QUOTE(Shocker @ Jul 22, 2007 - 9:51 ...   Jul 22, 2007 - 9:53 PM
|- - Shocker   QUOTE(presure2 @ Jul 22, 2007 - 9:53...   Jul 22, 2007 - 10:13 PM
- - jesterwr217   ok any idea how to get em in there i had a friend ...   Jul 22, 2007 - 11:49 PM
|- - presure2   QUOTE(jesterwr217 @ Jul 23, 2007 - 12...   Jul 23, 2007 - 5:22 AM
|- - jesterwr217   QUOTE(presure2 @ Jul 23, 2007 - 6:22...   Jul 23, 2007 - 10:35 AM
|- - presure2   QUOTE(jesterwr217 @ Jul 23, 2007 - 11...   Jul 23, 2007 - 6:41 PM
- - Shocker   Ive got it.... On you SAFC put your imput a 4 and ...   Aug 6, 2007 - 11:19 PM
|- - jesterwr217   QUOTE(Shocker @ Aug 7, 2007 - 12:19 ...   Aug 7, 2007 - 12:22 AM
|- - presure2   QUOTE(jesterwr217 @ Aug 7, 2007 - 1...   Aug 7, 2007 - 5:49 AM
|- - Shocker   QUOTE(presure2 @ Aug 7, 2007 - 5:49 ...   Aug 8, 2007 - 1:43 AM
- - jesterwr217   yea it doesnt sound very safe lol but i desperatel...   Aug 7, 2007 - 9:20 AM
|- - presure2   QUOTE(jesterwr217 @ Aug 7, 2007 - 10...   Aug 7, 2007 - 11:55 AM
- - NuclearHappineS   How come you guys NEVER understand this ... it...   Aug 7, 2007 - 1:44 PM
|- - jesterwr217   QUOTE(NuclearHappineS @ Aug 7, 2007 - 2...   Aug 8, 2007 - 12:53 AM
- - NuclearHappineS   a 12:1 FMU at 8 psi is a fuel rail pressure of 136...   Aug 8, 2007 - 1:19 AM
|- - jesterwr217   QUOTE(NuclearHappineS @ Aug 8, 2007 - 2...   Aug 8, 2007 - 2:40 AM
- - NuclearHappineS   >>with that setup your telling the SAFC that...   Aug 8, 2007 - 3:16 AM
- - Shocker   Im using that in conjunction with the 2 bar. Im go...   Aug 8, 2007 - 9:46 AM
- - Shocker   This is What Brad sent me today.Should clear up an...   Aug 10, 2007 - 3:13 PM
- - NuclearHappineS   Here's where he's right the voltage vs v...   Aug 10, 2007 - 3:22 PM
- - Shocker   thats better than the simple im sorry hes wrong.   Aug 11, 2007 - 11:52 AM
Lo-Fi Version Time is now: August 31st, 2026 - 3:43 PM
