> need help wiring my amplifier., I do not want to drill firewall/.
post Jul 5, 2007 - 11:07 AM
Any specific ideas where to pass the amp wire. In my corolla y was able to d it with my wire harness hole. This celica is so tight, i dont know where to pass. The only option is pass it though the door. Anybody any ideas how you did it, with pics if possible....
post Jul 5, 2007 - 11:39 AM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Looking at the engine bay standing in front of the car look on the left side. There is a rubber seal with a bundle of wires coming out. I fed my power cable to my battery in the trunk through that rubber grommet. You should be able to remove two nuts and it will come off. Anyway, if you feed it through there the wire will come out in the passenger side foot area and then you can run it under the carpet or something.
post Jul 5, 2007 - 11:43 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
same here... it works great and comes out right below the glove box... i tried a thousand other places and this definitely works best
Breaking Axles...
post Jul 5, 2007 - 2:43 PM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
i fed it through the firewall on the drivers side mine had a hole there already with stock wiring running through it??
post Jul 5, 2007 - 5:25 PM
Valo666
Joined May 15, '05
From Toronto
i ran mine through the gromet on the drivers side kick pannel. Had to take off the inner splash sheild, but ran it up, zip tied it to the rest of the harness, then ran it right out beside the battery.
post Jul 5, 2007 - 6:12 PM
thanks guys i will look into it tomorrow....
post Jul 5, 2007 - 6:30 PM
Bricy
Joined Mar 28, '07
From Odenville, Alabama
any idea where i can run mine in a ST? looked for the gromet on the left but didn't see anything.
post Jul 5, 2007 - 7:53 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
You either slit a hole on the main gromment going from engine bay into interior
or
Jack the car up . Remove wheel and splash guard. Run wire along the top and into the cabin through an existing grommet.Leads to kickpanel. This is a much cleaner way of running the power as you would not have a power cable running across the engine bay, instead you can drop it straight down next to the battery .
post Jul 5, 2007 - 11:35 PM
Bricy
Joined Mar 28, '07
k I found the hole and got everything wired up but is my amp light supposed to stay on when i turn the car off?
post Jul 6, 2007 - 12:51 AM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
Negative. What kind of amp do u have?
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Jul 6, 2007 - 1:55 AM
soven
Joined Mar 14, '05
amps should be turned on and off based on its remote wire. Run a remote wire from your headunit to your amp instead of wiring the remote wire input to a constantly on source.
post Jul 6, 2007 - 7:41 AM
Bricy
Joined Mar 28, '07
where do i wire it at on my headunit? i heard you put it in the radio plug is that true? btw my radio is old it has the preamps but no spot for the remote wire.
post Jul 6, 2007 - 6:17 PM
Bricy
Joined Mar 28, '07
just a heads up, i was at work today and was brainstorming and figured out that if i wrapped the remote wire around a different fuse then maybe the amp would shut off when the car is off. I picked the wiper fuse since its a bigger fuse and wal-a it worked! but i still dont understand why the sterio fuse has juice even when the car is off....
post Jul 6, 2007 - 6:23 PM
pepsiman
Joined Jun 3, '06
I always thought the head unit had constant power for clock memory
This post has been edited by pepsiman: Jul 6, 2007 - 6:24 PM
post Jul 6, 2007 - 6:38 PM
CaliJeff
Joined Apr 22, '07
theres 2 or so wires for head unit power.
12 volt constant (Always on)
12 volt acc. (turn rest of the unit on)
there might be more. can't remember right now.
post Jul 7, 2007 - 4:43 PM
QUOTE(CaliJeff @ Jul 6, 2007 - 7:38 PM) [snapback]575711[/snapback]
This is right.
I am going for the left fender to tuck my amp wire. Nasty little plugs to take out tough. It is much neater than the set up i had with my rolla. I cant wait to plug my amp into my stock 6 disc.
Thanks for all the suggestions...
Lo-Fi Version Time is now: July 11th, 2026 - 11:24 AM
