Jul 7, 2007 - 3:28 PM
Enthusiast ![]() ![]() Joined Oct 11, '06 From calgary Currently Offline Reputation: 5 (100%) |
I'm thinking of buying one of these three sets, according to the compatibility list they have they all fit a 94 celica but they don't garuntee anything and once i buy them i'm stuck with them so...
just asking if they will all fit and will they need any spacers to not look flushed in? Choice 1: Style: ADR battle exe Bolt Pattern: 5x100 or 5x114.3 Size: 18"x7.5" Offset: +42mm Tire Size: 225/40r18 OR 215/35/18 Choice 2: Style: ADR cypher Bolt Pattern: 5x100 or 5x114.3 Size: 17"x7" Offset: +42mm Tire Size: 205/40zr17 Choice 3: Style: ADR BATTLE EXE Bolt Pattern: 5x100 or 5x114.3 Size: 19"x7.5" Offset: +42mm Tire Size: 235/35/19 This post has been edited by black13: Jul 7, 2007 - 3:29 PM |
Jul 7, 2007 - 3:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
they will all fit, I would go with the ADR cypher 17's just make sure you don't get 205/40/17 tires go a little bigger, because I had ADRs and with those 205 tires you would have to baby the wheels as any pot hole would send them to the dumpster.
Jul 7, 2007 - 4:31 PM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
Jul 7, 2007 - 6:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
QUOTE(Culpable04 @ Jul 7, 2007 - 3:44 PM) [snapback]575933[/snapback] they will all fit, I would go with the ADR cypher 17's just make sure you don't get 205/40/17 tires go a little bigger, because I had ADRs and with those 205 tires you would have to baby the wheels as any pot hole would send them to the dumpster. agreed....going 17s are teh way to go.....goign 18"+ is not recommended..... -------------------- ![]() |
Jul 7, 2007 - 6:24 PM
QUOTE(Culpable04 @ Jul 7, 2007 - 3:44 PM) [snapback]575933[/snapback] they will all fit, I would go with the ADR cypher 17's just make sure you don't get 205/40/17 tires go a little bigger, because I had ADRs and with those 205 tires you would have to baby the wheels as any pot hole would send them to the dumpster. hmm good to know thanks. So I'm gonna go for those and if I upgrade the tires to 215/45/17 it should be good then? |
Jul 8, 2007 - 12:13 AM
QUOTE(black13 @ Jul 7, 2007 - 6:24 PM) [snapback]575969[/snapback] QUOTE(Culpable04 @ Jul 7, 2007 - 3:44 PM) [snapback]575933[/snapback] they will all fit, I would go with the ADR cypher 17's just make sure you don't get 205/40/17 tires go a little bigger, because I had ADRs and with those 205 tires you would have to baby the wheels as any pot hole would send them to the dumpster. hmm good to know thanks. So I'm gonna go for those and if I upgrade the tires to 215/45/17 it should be good then? yeah, that'll work -------------------- ![]() |
Jul 8, 2007 - 7:26 AM
Enthusiast ![]() Joined Jan 8, '07 From Sunderland UK Currently Offline Reputation: 0 (0%) |
I've just fitted 17*9 with an offset of 35mm,with 225/45's and they have lots of clearance no spacers just fit inside of wheel arch. see my profile.
keith This post has been edited by topshed: Jul 8, 2007 - 7:27 AM |
| Lo-Fi Version | Time is now: August 24th, 2026 - 11:38 PM |
