> Radiator upgrade?
post Jul 8, 2007 - 12:47 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
As I was tidying up my engine bay with some heat resistant paint (pictures below tongue.gif ), i noticed that my radiator has been slowly changing color. i remember on a thread somewhere that if it gets to some certain color, it needs to be changed. Does anyone know how often a radiator needs to be changed, if ever? If one were to change it, does there exist an "upgrade" to the radiator?
There's a spot where some take got stuck on the cover. kindasad.gif Other than that, it turned out alright. Been driving it for awhile now and there has been no problems with the heat.
post Jul 8, 2007 - 8:52 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
an upgrade would be the Koyo radiator
http://cgi.ebay.com/ebaymotors/KOYO-RACING...sspagenameZWDVW
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jul 9, 2007 - 1:32 AM
Slick
Joined Jan 10, '06
QUOTE(K-ESD @ Jul 9, 2007 - 3:52 AM) [snapback]576283[/snapback]
Thanks! So there wouldn't be any problems with the hose connections?
post Jul 9, 2007 - 6:51 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Connections line up just fine. Only remember that the Radiator itself is 2+ inches thick (55mm IIRC) with a 3SGTE it could get fitting issues with the normal radiator fans hitting the turbo, but you will have enough room between the radiator and your header with the 3S-GE.
This post has been edited by Kadett: Jul 9, 2007 - 6:52 AM
post Jul 9, 2007 - 10:30 AM
Slick
Joined Jan 10, '06
QUOTE(Kadett @ Jul 9, 2007 - 1:51 PM) [snapback]576414[/snapback]
post Jul 9, 2007 - 11:56 AM
Kadett
Joined Mar 17, '05
Here are some pics in comparion of the ST205 and another aftermarket radiator. As you can see for yourself. The Koyo line's up perfectly with factory holes and fittings.
post Jul 9, 2007 - 2:50 PM
Slick
Joined Jan 10, '06
Excellent! Great informative pictures! You wouldn't happen to know the weight of the radiator? I'm hoping I can get it through the Embassy pouch. As long as its not over 50 lbs i'm good.
post Jul 9, 2007 - 4:11 PM
Kadett
Joined Mar 17, '05
5.9kgs according to gtfour.co.uk.
Lo-Fi Version Time is now: June 28th, 2026 - 2:17 PM
