> Suspension, OEM Suspesion
post Jul 10, 2007 - 9:47 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
sup fellas....need some help here...had my 97 ST for 7 years now....my suspension has been through alot of changes...first i had dropzone coilovers with KYB GR2 shocks...the cheap coilovers killed my shocks...then i decided to go with Koni shocks with Ground Control coilovers which most people thought was a very good setup...Tein are just too crazy expensive...now my shocks are dead again...i believe i lowered the car too low and being in a place with lots of potholes and bumps didn't help...i just wanna go back to stock set up...where can i buy a new OEM strut asssembly without messing with the springs and shocks...
any suggestions would be appreciated
post Jul 10, 2007 - 11:45 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
KYB GR-2's = OEM replacement.
If you need OEM springs I have a set.
**** Photobucket
post Jul 14, 2007 - 2:34 AM
djyohimbe
Joined Jul 16, '05
From Vancouver, BC Area
QUOTE(Ve1Ls1dEvolutioN @ Jul 10, 2007 - 7:47 PM) [snapback]577153[/snapback]
I'd be happy to sell you my rear OEM shocks...
post Aug 2, 2007 - 9:38 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
i too have a oem suspension set at my house. BUT one of the front struts is bent.
btw how much did all your suspension cost you in the first place from beginning to end? probably near the cost of a tein setup.
post Aug 17, 2007 - 7:58 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
QUOTE(purplegt4 @ Aug 2, 2007 - 7:38 AM) [snapback]584643[/snapback]
yeah exactly...spent $400 on ground control coilovers then $600 on Koni adjustable shocks...i just wanna go back to stock...what is the closest spring to stock height?? dont want any drop...lots of potholes and bumps here in NYC...
post Aug 17, 2007 - 8:25 PM
Jared95
Joined Apr 24, '07
From lufkin tx
well i just installed some eibachs 1.5 in sportlines and they are making alot of popping noises i know they will make some noise when first installed to adjust but how long will it continue? iv had them on for a good 1 and half weeks or more?
post Aug 17, 2007 - 11:24 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
what's the closest i can get to stock height?? eibach prokit or tein S tech??
planning on getting KYB GR2
post Aug 18, 2007 - 1:02 PM
purplegt4
Joined Feb 7, '03
eibach pro-kit or trd springs
post Aug 18, 2007 - 1:44 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
QUOTE(purplegt4 @ Aug 18, 2007 - 11:02 AM) [snapback]588939[/snapback]
is the eibach pro-kit springs okay with the KYB GR-2 shocks?? do i have to get those boots inside the springs?? or does it come with it when i buy the eibach pro-kit springs?
post Aug 18, 2007 - 7:24 PM
Jared95
Joined Apr 24, '07
From lufkin tx
letting u know get a order a boot seperate mine was ripped and i figured a new one would come with the GR2s but it didnt...they seals are really tight on them though so i just said screw it and but them on with no boot
post Aug 19, 2007 - 8:28 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
am i able to use the housing that the strut sits on?? i bought the KYB GR-2 shocks...and the front are inserts only...am i able to unscrew the front inserts??
Lo-Fi Version Time is now: August 4th, 2026 - 9:13 AM
