Jul 12, 2007 - 4:05 AM
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) |
i need to get some advice on drilled + slotted rotors.
from what i've read on here before it seems like slotted is good. but cross-drilled is bad (leads to cracking allot) i've been warping rotors allot. so i think i should try to upgrade to better ones. my mechanic says he found some that are cross-drilled and slotted, and have a lifetime warranty. i think they cost something like a 120usd per rotor. lifetime warranty alone sounds worth the money. is there any chance that the cross-drilling isn't going to lead to the rotors cracking? also, do performance brake rotors wear your brake pads down quicker? thanks in advance ny |
Jul 12, 2007 - 9:45 AM
if your warping rotors allot, id get that fixed 1st..chances are you have a bad bearing causing uneven braking therefore rotors warp.
Jul 12, 2007 - 4:00 PM
i didn't think that'd be the cause...good call. yes, i absolutely do have a bad bearing. which damaged something else which will take a few days to get here too
any thoughts on the slotted + cross drilled brake rotors? |
Jul 12, 2007 - 4:40 PM
slotted for fronts and blanks for rear will do...$35 and $30 so $130 for all 4 at tirerack.
Jul 12, 2007 - 4:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
cross dilled and/or slotted is help against brake fade. Brake fade is expirenced usually while course racing or cayon carving due to high speed braking. Since brakes work by causing friction, which causes heat, the fuild can get really hot and maybe even boil.
So to solve this, some use slotted/drilled rotors to disspense heat better. Odds are you'll prob never expirence brake fade on your daily driver, so the rotors are really just for looks. -------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jul 13, 2007 - 1:52 AM
Enthusiast ![]() Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) |
QUOTE(SlowCelica94 @ Jul 12, 2007 - 4:50 PM) [snapback]577938[/snapback] cross dilled and/or slotted is help against brake fade. Brake fade is expirenced usually while course racing or cayon carving due to high speed braking. Since brakes work by causing friction, which causes heat, the fuild can get really hot and maybe even boil. So to solve this, some use slotted/drilled rotors to disspense heat better. Odds are you'll prob never expirence brake fade on your daily driver, so the rotors are really just for looks. Does anyone have experience with drilled & slotted rotors warping/cracking under normal conditions for a daily driver? Does the cross-drilling give a significant weight reduction? Drilled & slotted rotors seem to be cheaper than just slotted, so if they are durable for normal road use, and give a bit of a rotating mass weight reduction, might be best bang for the buck. |
Jul 13, 2007 - 10:29 AM
according to wikipedia cross-drilled brakes are for looks and weight reduction. but it also mentions them under the cracking section.
http://en.wikipedia.org/wiki/Disc_brake#Cracking i always assumed it would help with cooling, even though it's less mass, it exposes more surface area to the air. like why heat-sinks on chips have fins instead of being a block of metal. still sorta thinking about it 'cause of the lifetime warranty bit. |
Jul 13, 2007 - 11:52 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
stock blanks are the best. Just use them
Jul 13, 2007 - 2:57 PM
just read a ton of stuff on a corvette forum. almost everyone suggests that drilled or slotted rotors were only useful with the brake pads 20 years ago.
i like the idea of a lifetime warranty on my brake rotors, but first and foremost i want my brakes to stop my car quickly. guess i should stick with plains. |
Jul 13, 2007 - 3:29 PM
blanks provide more surface area too.
And yes, I've seen people crack and break that at the PutmanPark road course. -------------------- NASA/SCCA RX-7....currently under the knife
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:41 PM |
