Jul 14, 2007 - 12:27 AM
Enthusiast Joined Jul 4, '07 Currently Offline Reputation: 0 (0%) |
Have just installed 2 x 8" Boschmann Subs that come as part of a component set into the front doors, they fit perfectly into the stock mount, found it quite easy getting the speaker wire through from the door into the cab as well, definately alot easier than i expected, maybe 1 hours work total.
Now have those in the front doors with fusion powerplant 6.5" 2 ways in the rear all running off fusion 4 channel powerplant 800w amp, sounding good. Plans for the future to have component sets for both fronts and rears and 1 or maybe 2 12" powerplant woofers in the trunk. Any thoughts or suggestions? Cheers |
Jul 18, 2007 - 2:22 PM
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) |
Do your doors rattle to hell or did you add something to fix that?
So you have 2 8" subs in the front and 2 6.5" in the back. I assume you have the tweeters but do you have the doors with the 3 1/2" as well? Otherwise I'm not sure I would like the sound balance in that setup. Do you just run the 8's and the 6.5's? Pics? -------------------- |
Jul 19, 2007 - 2:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
QUOTE(Sinyk @ Jul 18, 2007 - 7:22 PM) [snapback]579885[/snapback] Pics? x2 -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
| Lo-Fi Version | Time is now: June 25th, 2026 - 12:49 AM |
