Jul 14, 2007 - 12:55 PM
Enthusiast ![]() Joined Jun 28, '07 Currently Offline Reputation: 0 (0%) |
Any known hub assemblies that can be directly swapped onto our celicas so we have a better choice of used wheels?
Buying new wheels is a total waste(70% anyways), and 5x114 seem to be way more common. Alternateley, what do people think about adapters? Thanks! |
Jul 16, 2007 - 1:03 PM
Looked on ebay, one pair of adapters is $60 plus shipping! Obviously not an option.
Jul 17, 2007 - 2:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
I wondered this exact same thing. i wanted 5x114 Knuckles so i went to the junk yard and i there was a 6gc with no Knuckle and camry which had the Knuckle removed. I took the camry knuckle to the celica and they are very identical but the camry knuckle is just a bit too big! the bolts are spaced wider and therefore would not fit into the lower control arm. Also, the two holes for the shock tower are also spaced wider. Sooo..... no dice, unless you can redrill those holes to fit the celica, but i wouldnt recomend it
i went with a wheel adaptor 5x100 to 5x114. they fit great i got them custom made at www.wheeladaptor.com hope that helped This post has been edited by eggman40: Jul 19, 2007 - 1:19 AM |
Jul 18, 2007 - 2:10 AM
QUOTE(eggman40 @ Jul 17, 2007 - 2:31 PM) [snapback]579475[/snapback] i went with a wheel adaptor 5x100 to 5x114. they fit great i got them custom made at www.wheeladaptor.com hope that helped How much did they cost you there(for all 4)? |
Jul 18, 2007 - 2:12 AM
QUOTE(dutchboy @ Jul 18, 2007 - 12:10 AM) [snapback]579701[/snapback] QUOTE(eggman40 @ Jul 17, 2007 - 2:31 PM) [snapback]579475[/snapback] i went with a wheel adaptor 5x100 to 5x114. they fit great i got them custom made at www.wheeladaptor.com hope that helped How much did they cost you there(for all 4)? I got all 4 with a hub centric lip for like 320 i think |
Jul 18, 2007 - 6:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
QUOTE(dutchboy @ Jul 16, 2007 - 1:03 PM) [snapback]579126[/snapback] Looked on ebay, one pair of adapters is $60 plus shipping! Obviously not an option. How cheap are you trying to go? Don't you want your wheels to stay on the car? I doubt you will find a pair of hubs for that cheap [definitely not brand new], never mind the wheel bearings. They should also be changed if you change the hub. QUOTE(eggman40 @ Jul 17, 2007 - 2:31 PM) [snapback]579475[/snapback] I wondered this exact same thing. i wanted 5x114 hubs so i went to the junk yard and i there was a 6gc with no hub and camry which had the hub removed. I took the camry hub to the celica and they are very identical but the camry hub is just a bit too big! the bolts are spaced wider and therefore would not fit into the lower control arm. Also, the two holes for the shock tower are also spaced wider. Sooo..... no dice, unless you can redrill those holes to fit the celica, but i wouldnt recomend it i went with a wheel adaptor 5x100 to 5x114. they fit great i got them custom made at www.wheeladaptor.com hope that helped I already told you this in your wheel bearing thread, that is NOT the hub...... The hub is the piece that sits in the wheel bearing and has the wheel studs in it. The assembly you are talking about is the axle carrier or steering knuckle.... By using the wrong names you gave the wrong advice..... I don't know for sure if a Camry hub will fit a Celica wheel bearing, but you don't need to worry about it bolting to the strut or lower control arm, all it has to do is fit into the wheel bearing and fit the splined shaft on the outer CV joint. -------------------- ![]() |
Jul 19, 2007 - 1:06 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
QUOTE(alltracman78 @ Jul 19, 2007 - 1:13 AM) [snapback]579965[/snapback] How cheap are you trying to go? Don't you want your wheels to stay on the car? I doubt you will find a pair of hubs for that cheap [definitely not brand new], never mind the wheel bearings.They should also be changed if you change the hub. How much are we talking about here as far as used? If i post a WTB for some used hubs, do you think it would be possible? -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Jul 19, 2007 - 1:17 AM
[/quote]
I already told you this in your wheel bearing thread, that is NOT the hub...... The hub is the piece that sits in the wheel bearing and has the wheel studs in it. The assembly you are talking about is the axle carrier or steering knuckle.... By using the wrong names you gave the wrong advice..... [/quote] Holy Sh!t your right i completely forgot its the called the Knuckle. Ive called it a knuckle before in other brake realated threads, i dont know what i was thinking this time around.... I didnt notice your post in the write up, i havent seen it in weeks. But ill go back and change it up. Sorry guys complete F*up on my part. Edit: replied to your post in my write up This post has been edited by eggman40: Jul 19, 2007 - 1:38 AM |
| Lo-Fi Version | Time is now: July 28th, 2026 - 8:18 PM |
