> How do I tighten nut on top of strut?, nut on to of strut
post Jul 15, 2007 - 6:01 PM
juan_solid
Joined Dec 22, '05
From Turlock, CA
How do i tighten the nut on the top of the strut shaft withought the shaft moving?(KYB STRUTS)
Any input would be helpful! Thanks!
www.cardomain.com/id/snakesolid
Replies (1 - 9)
post Jul 15, 2007 - 7:41 PM
forkee
Joined Nov 13, '02
From So Cal
hmm i think i know what your talking about...heres what i did
place crowbar or similar shaped metal rod between any 2 of the 3 smaller surrounding bolts to anchor it and prevent it from rotating (i pushed mine into the grass for more support. then use a large socket wrench (i used a torque wrench) to tighten
This post has been edited by forkee: Jul 15, 2007 - 7:49 PM
post Jul 15, 2007 - 8:13 PM
juan_solid
Joined Dec 22, '05
From Turlock, CA
QUOTE(forkee @ Jul 15, 2007 - 7:41 PM) [snapback]578886[/snapback]
I might try that, there has to be a better way. The top of the shaft has a hex like hole, I tried all the metric and standard hex wrenches but none of them fit correctly Here is a pic of what i'm talking about:IPB Image
post Jul 16, 2007 - 1:49 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
If the shaft is spinning then its not seated into the top strut mount properly.
This post has been edited by bufferdan: Jul 16, 2007 - 1:49 PM
post Jul 16, 2007 - 2:19 PM
eggman40
Joined Aug 17, '04
From California
I used an electric impact gun. It spins it faster than the shock can rotate so actually tightens it
QUOTE(eggman40 @ Jul 16, 2007 - 12:17 PM) [snapback]579155[/snapback]
Edit: if you dont have impact gun, i would tighten it the best you can, then slowly drive it to a shop that does have an air gun. then just take the right socket with you. Just make sure its not too tight.
post Jul 16, 2007 - 2:40 PM
If the strut is moving, YOU DID NOT INSTALL IT CORRECTLY.
the strut slides into the perch so that it WILL NOT ROTATE
take it back out and install it correctly.
post Jul 16, 2007 - 3:21 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Word. It should only move up and down.. not spin. I used Air tools smile.gif
**** Photobucket
post Jul 16, 2007 - 3:29 PM
juan_solid
Joined Dec 22, '05
From Turlock, CA
Thanks for the input, I will make sure to take the strut back apart and put the mount on correctly so the piston won't spin so then I can tighten it. Thanks for the tips.
post Jul 16, 2007 - 3:36 PM
QUOTE(95CelicaST @ Jul 16, 2007 - 4:21 PM) [snapback]579188[/snapback]
air tools FTW
post Jul 17, 2007 - 10:40 AM
Rayme
Joined Feb 18, '06
From NB, Canada
A bas strut mount might also be the reason it rotates, as the notch where the cylinder enter might be damage. Happened to me.
-Rémy
02 SiR, 08 250R
Lo-Fi Version Time is now: September 12th, 2026 - 6:11 AM
