Jul 20, 2007 - 6:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
Basically, I heard it today while driving...I have had my axles changed almost a year ago and the only thing left that i need to do is change my brake pads, which i plan to do soon....I was driving down the streets when i suddenly heard a noise, squealing squeaky noise coming from my front right or left side of the car....i wasn't breaking but it sounded like the noise came from the rotors as if your brakes completely going out and the calipers are grinding on the rotor....the sound will only show up as i make a hard left turn (U-turn, slowly) or just in gear slowing down without pressing on the brake i can hear the squealing seemingly coming from the front rotors...should i just change my brake pads ( thus saying it is my brakes going out) and be okay, or it is something else? I thought stepping on the brake, if it squeals means the pads are out and that i need to change asap...?
Jul 20, 2007 - 6:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
what speed does it squeel at? 10mph? 50 mph?
does it squeel when your car is at a stop? |
Jul 20, 2007 - 7:02 PM
drive down to see me already!
Jul 20, 2007 - 9:28 PM
i had to replace my bearings when thishappened... all was good afterwards
Jul 20, 2007 - 10:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) |
lol...its happening to me now...ill be fixing it all soon, new tein shocks, KOYO springs....and so forth....thats on the spring side..but you sure its the bearings....not anything else? cuz my springs are makin noises...when i go on a bump
Jul 21, 2007 - 12:58 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
Sounds like it could be a wheel bearing. The best way to check is have a professional front end inspectition done.
-------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jul 21, 2007 - 3:04 AM
generally around 10-20 mph...or less...weird...but then again it should be expected because this is a 13yr old car...thanks for all your input, it really helps...wheel bearing huh? anyone has the pics? or even diagram of where that is? could it be springs...? when i go over bumps, nothing really, it just occurs when i make a sharp hard left turn or decrease in my speed while in gear...example...2nd or 3rd gear still in gear slowing down then it squeals...weird right?
This post has been edited by chacha: Jul 21, 2007 - 3:09 AM |
Jul 21, 2007 - 7:25 AM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
yea weird, its happening to me, only when im going straight or turning right, not left.
If its hurting the car then lemme know how you fixed it, but if its not then i dont really wanna fix it lol. |
Jul 21, 2007 - 8:18 AM
Enthusiast ![]() ![]() ![]() Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
If it's only when you turn, you need to replace the power steering belt.
Jul 21, 2007 - 11:37 AM
happens when im goin straight to, still power stearing?
Is it hard to change out? |
Jul 21, 2007 - 11:50 AM
QUOTE(celica3sgte @ Jul 21, 2007 - 1:18 PM) [snapback]580797[/snapback] If it's only when you turn, you need to replace the power steering belt. If highly doubt it, belt squels have a very different tone and pitch. -------------------- NASA/SCCA RX-7....currently under the knife
Jul 21, 2007 - 4:02 PM
no.,..this sounded like the noise of a rotors being grind by the calipers...when the brakes are out...only when i slow down and when i turn...i think it might be the bearings too...regardless, changing wheel bearings out of a 13 yr old car wouldn't be too bad of an idea either...it is rather old...
Jul 21, 2007 - 10:06 PM
I'm pretty certain it's wheel bearings. Just be safe and do both, it'll help keep the car balanced too during harder cornering
Jul 23, 2007 - 8:02 AM
where do you buy the bearings besides at the dealership?
Jul 23, 2007 - 9:15 AM
you need to talk to me more!
Jul 23, 2007 - 11:05 AM
QUOTE(chacha @ Jul 23, 2007 - 1:02 PM) [snapback]581434[/snapback] where do you buy the bearings besides at the dealership? most any parts store -------------------- NASA/SCCA RX-7....currently under the knife
Jul 24, 2007 - 11:06 AM
i say buy a toyota bearing, unless you really trust autozone or whoever...
1stoyotaparts is your friend and mine as well -------------------- ![]() |
Jul 24, 2007 - 8:55 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
^ Word
It could also be the dust deflector. The ring over the ABS teeth. If it comes loose it can cause noise. Check that first. -------------------- ![]() |
Jul 26, 2007 - 1:20 PM
Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
lift the front of the car in the air and try to wiggle the wheel from top to bottom, if it wiggles...you need a wheel bearing or at least it should be looked at.
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Jul 26, 2007 - 3:21 PM
If it wiggles check WHERE it's wiggling.
There are other parts besides the wheel bearing that hold the wheel steady. -------------------- ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 9:35 AM |
