> 3sgte WOT prob
post Jul 26, 2007 - 3:05 PM
19celica90
Joined Jun 1, '07
From DeKalb
well couple days ago my 3s started acting up, rough idle, hesitation and missing alot. So i checked the plugs and they looked worn so i replaced them along with then distributor cap and rotor. Now it idles fine. But, whenever the car is warmed up and out of the "safe mode" it kinda looses power. For example, when im driving 1st and 2nd are good, not affected, but my 3rd 4th and 5th the car sounds like its farting, like a prrrt prrrt prrt sound, lol best i could do. if i accelerate slowly and build boost slowy it doesnt do it at all. but say i wanna merge into traffic or take off and go wot it does the prrt thing. So i thought boost leak cuz its doing it under boost so it seems load based. checked out my piping, everything solid, not hissing from pipes or intercooler, havent done an actual boost leak test but i will soon. i did notice on my dp i had two hairline cracks. both right after the 1st o2 sensor, and im wondering if the 2nd sensor isnt seeing all the exhaust and maybe trying to compensate but i dunno. any feedback would be great guys, thanks
post Jul 27, 2007 - 11:29 AM
your bov might need adjusting.
do the boost leak test too.
post Jul 29, 2007 - 11:16 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Change your spark plug wires!!!
post Jul 29, 2007 - 2:07 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
"So i checked the plugs and they looked worn so i replaced them along with then distributor cap and rotor"
post Jul 29, 2007 - 2:31 PM
19celica90
Joined Jun 1, '07
From DeKalb
i didnt change the wires when i posted cuz i was waiting on them from the dealership, i was posting to see if anyone could shed some light if it were something not with the ignition
post Jul 29, 2007 - 2:36 PM
most of these issues are cause by one of the following...
1. boost leak (check intake from afm to turbo too)
2. ignition
3. afm
4. TPS
5. coolant temp sensor
6. knock response (easy to monitor with the tvsv mod)
go down the list and check them all one by one in this order.
post Jul 29, 2007 - 4:22 PM
19celica90
Joined Jun 1, '07
From DeKalb
came home and my new wires were here, put em on and problem solved.
post Aug 2, 2007 - 2:40 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(DG_Performance @ Jul 29, 2007 - 9:16 AM) [snapback]583388[/snapback]
dam... good call dave
Lo-Fi Version Time is now: August 29th, 2026 - 7:45 PM
