> iam running my st celica at the track what #'s should i expect
post Jul 26, 2007 - 7:19 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
Well this friday iam going to the 1/8 of a mile track and well i want to now what kind #'s should i be running..my mods are cold air and thats it ...i just want to run my car to see where do i stand before i do my 3sgte swap biggrin.gif
post Jul 26, 2007 - 11:03 PM
Redline08
Joined Feb 23, '07
From Albany, NY
i know the st can barely break 20 with perfect driving, but thats on a 1/4mile
search "1/8 mile time calc" or "quarter mile calculator" on google
the st probably has 80-85hp if lucky, youll need it to put in calcs
post Jul 26, 2007 - 11:20 PM
stock ST celica, about 17.5-17.9 for the 1/4 mile.
burnyd
Joined Oct 13, '06
From Pittsburgh
there is an event at norwalk Ohio every january 1st called the hangover nationals.. you have to go 21.7 I think it is in the 1/4 to win lol... like exactly 21.7... and you have to beat your oponent.
I brought my 97 ST... When I actually tried I was crackin away at 17s!
And my motor is healthy... lol.. in the 1/8 mile youll prolly hit 12s heh.
post Jul 27, 2007 - 9:08 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
so i should be running high 11 s in the 1/8 of a mile?
This post has been edited by 02bluerolla: Jul 27, 2007 - 9:08 AM
post Jul 27, 2007 - 9:25 AM
thats my time slip
this is what my car looked like
14" wheels running 22psi in the tires on Dunlop Sp2 tires (i think thats the tire)
exhaust, AEM cold air, clutch, short throw shifter.
and as you can see from the 60' times (they are bad @ 2.5).
I had several runs faster than this (not scanned in) @ 17.2sec in the 1/4.
I haven't seen anyone post anything faster for an ST non turbo
This post has been edited by playr158: Jul 27, 2007 - 9:26 AM
post Jul 27, 2007 - 4:31 PM
95celgt
Joined Oct 5, '03
From South TX.
my st hit 16.9 @79.77 mph in the 1/4, fully stock body with full interior and 18IN WHeels with an exedy clutch, no cat with rice muff, and a cold air....
post Jul 27, 2007 - 5:17 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
Stock celica st has 90.5 HP, just for your info. You should be running somewhere at high 11 sec. That's what I had on 1/8 mile.
post Jul 28, 2007 - 12:08 AM
Redline08
Joined Feb 23, '07
From Albany, NY
90.5 hp is overestimated i THINK, show me some dyno sheets and i will admit to being wrong but IMO a car that has 110 at the crank out of the factory shouldnt have 90.5 to the wheels after at least 8 years...
post Jul 28, 2007 - 10:49 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
it rained out so the track was closed *crys*
post Jul 28, 2007 - 1:08 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
Here is a Celica running HS class. Stock Celica ST 90.5 HP on dyno...
This is the link.
http://grassrootsmotorsports.com/archives/celicast.html
You can check it out your self. There is a dyno sheet with HP and Torque map.
This post has been edited by miro1975: Jul 28, 2007 - 1:09 PM
Lo-Fi Version Time is now: September 14th, 2026 - 5:49 PM
