Jul 30, 2007 - 3:01 AM
Enthusiast ![]() Joined Nov 22, '06 From Maui, HAWAII Currently Offline Reputation: 0 (0%) |
I recently posted a question about Power Distribution Block and found the answer on carstereo.com forum. I have a new question-I need to connect 2 A/V converter box that has 12v power wire(red), 12v accessory wire (yellow) and a ground wire (balck) to the connector. I pretty sure the red wire connects to the car battery and the black wire needs to coonected to an nearby bolt, but were do I connect the yellow wire?
Jul 30, 2007 - 9:42 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
QUOTE(MauiBuilt @ Jul 30, 2007 - 4:01 PM) [snapback]583599[/snapback] I recently posted a question about Power Distribution Block and found the answer on carstereo.com forum. I have a new question-I need to connect 2 A/V converter box that has 12v power wire(red), 12v accessory wire (yellow) and a ground wire (balck) to the connector. I pretty sure the red wire connects to the car battery and the black wire needs to coonected to an nearby bolt, but were do I connect the yellow wire? yellow goes to + batt, red to accessory + and black to ground. -------------------- ![]() 98% completion --- aaRon |
Jul 30, 2007 - 2:49 PM
QUOTE(lubu @ Jul 30, 2007 - 2:42 PM) [snapback]583646[/snapback] QUOTE(MauiBuilt @ Jul 30, 2007 - 4:01 PM) [snapback]583599[/snapback] I recently posted a question about Power Distribution Block and found the answer on carstereo.com forum. I have a new question-I need to connect 2 A/V converter box that has 12v power wire(red), 12v accessory wire (yellow) and a ground wire (balck) to the connector. I pretty sure the red wire connects to the car battery and the black wire needs to coonected to an nearby bolt, but were do I connect the yellow wire? yellow goes to + batt, red to accessory + and black to ground. You are right and I was wrong. So the accessory wire also connects to the battery? Will it be connected to the postive post or negative post? |
Jul 30, 2007 - 5:10 PM
um no..
yellow goes to positive batt red goes to ignition on or accesorry +, meaning you connect red to a wire that feeds 12+ when you turn the key to on. blacky to ground -------------------- ![]() 98% completion --- aaRon |
Jul 31, 2007 - 12:20 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
red and yellow wires are found behind the head unit with the adaptor harness for the new headunit
-------------------- Breaking Axles...
| Lo-Fi Version | Time is now: September 13th, 2026 - 4:48 AM |
