Jul 30, 2007 - 4:41 AM
Enthusiast ![]() ![]() Joined Oct 11, '06 From calgary Currently Offline Reputation: 5 (100%) |
k so I've managed to fix most everything with my car except for the clock/headlight/and the roof light thats burnt out.
Firstly for the clock, mine doesn't work. Or at least it stopped working after some fuses were burnt out in my car and I'm guessing one of them was in the clock, so will I need a new clock or is there a way to repair it? If I need a new one, I would like to get some non-stock clock that looks a little better with a blue light. Where can i get one of these? Secondly, my low beam headlights that are the outer headlights don't work. Or at least they work until the second I put the car in Drive mode. After that they just all light up in high beam mode. How can I fix this? Also, for the roof light, what voltage does the lamp have to be? |
Jul 30, 2007 - 9:41 AM
Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
the clock sounds like you need to replace the fuse..
the headlights sound wierd, maybe a wiring problem with the light stick thing -------------------- |
Jul 30, 2007 - 11:07 AM
is that fuse located in the fuse box under the hood? Weird cause I checked those fuses and they were all fine. Albeit there were some missing but thought that was how its supposed to be.
Jul 30, 2007 - 3:06 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
the clock fuse should be under teh steering wheel in the interior fuse box
Jul 31, 2007 - 1:56 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) |
QUOTE(black13 @ Jul 30, 2007 - 11:07 AM) [snapback]583674[/snapback] is that fuse located in the fuse box under the hood? Weird cause I checked those fuses and they were all fine. Albeit there were some missing but thought that was how its supposed to be. lol? Missing? |
Jul 31, 2007 - 1:59 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
headlights most likely sound like a relay problem
-------------------- Breaking Axles...
| Lo-Fi Version | Time is now: May 15th, 2026 - 10:50 PM |
