Aug 2, 2007 - 7:50 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
My car is progressively going into low boost mode. I have the led "safe mode" monitors. At first it would go into LBM (low boost mode) after idle for a while on a hot day. Then, on the highway for about 20 minutes on a HOT day it would go to LBM. Now after about 10 minutes on a cold start, it goes into LBM. I started checking coolant temp. sensors with the ohm meter and checking over the harness for bad wires and connections. But I couldnt find in the toyota manuals what this one sensor does or how to check it. The only thing I can figure is its on of the many sensors that give the ecu the ok to boost. Anyways, I pulled on the wire (lightly) and it broke. So Im going to price one at toyota tomorrow. Can anyone confirm what sensor this is and what it does? Sorry for the long post. I thought you may need my reasoning for messing with the sensor. BTW its the sensor in the middle of the picture on the back of the block. Its suppost to have a single wire come out of the top and a connector. Thanks
This post has been edited by toyotacrazy: Aug 2, 2007 - 7:51 PM |
toyotacrazy Car still going into low boost mode! Aug 2, 2007 - 7:50 PM
lagos im pretty sure thats a coolant temp sensor for the... Aug 2, 2007 - 8:27 PM
toyotacrazy QUOTE(lagos @ Aug 2, 2007 - 8:27 PM)... Aug 2, 2007 - 9:13 PM
lagos QUOTEAfter about 10 minutes from the time I starte... Aug 2, 2007 - 11:28 PM
toyotacrazy QUOTE(lagos @ Aug 2, 2007 - 11:28 PM... Aug 3, 2007 - 5:50 AM
lagos and let me guess..... you normally notice this whi... Aug 3, 2007 - 10:40 AM
toyotacrazy QUOTE(lagos @ Aug 3, 2007 - 10:40 AM... Aug 3, 2007 - 1:00 PM
lagos whats the part number on the afm. that should tell... Aug 3, 2007 - 1:13 PM
toyotacrazy QUOTE(lagos @ Aug 3, 2007 - 1:13 PM)... Aug 3, 2007 - 4:33 PM
toyotacrazy My afm part # is 22250-74170
can anyone verify t... Aug 3, 2007 - 4:47 PM
lagos yeah thats the same part number as my afm. do the... Aug 3, 2007 - 4:52 PM
toyotacrazy QUOTE(lagos @ Aug 3, 2007 - 4:52 PM)... Aug 3, 2007 - 4:53 PM
lagos yes.
what readings to you get from VS-E2 with the... Aug 3, 2007 - 4:55 PM
toyotacrazy QUOTE(lagos @ Aug 3, 2007 - 4:55 PM)... Aug 3, 2007 - 4:58 PM
toyotacrazy I dont know if these pics will help you or not. I... Aug 3, 2007 - 6:05 PM
lagos dood... did you just remove your harness plug... Aug 4, 2007 - 2:06 AM
toyotacrazy QUOTE(lagos @ Aug 4, 2007 - 2:06 AM)... Aug 4, 2007 - 11:44 AM
lagos QUOTEThe harness plug had been out before I got it... Aug 4, 2007 - 12:04 PM
Gary What Art said, the harness plug should NEVER been ... Aug 4, 2007 - 12:05 PM
toyotacrazy QUOTE(Gary @ Aug 4, 2007 - 12:05 PM)... Aug 4, 2007 - 3:04 PM
toyotacrazy I just relocated my maf in front of my drivers whe... Aug 12, 2007 - 9:47 PM
lagos hot air is not your problem. the fact that your h... Aug 12, 2007 - 11:15 PM
toyotacrazy QUOTE(lagos @ Aug 12, 2007 - 11:15 P... Aug 13, 2007 - 1:36 PM
lagos i keep trying to tell you, heatsoaking the maf won... Aug 13, 2007 - 2:04 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 8:29 PM |
