Aug 3, 2007 - 7:57 PM
Enthusiast ![]() ![]() Joined Jan 17, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
Hello my 94 celica GT has gone from running *only* at idle to not firing at all it is dead in the water. I have checked for spark and fuel both are there. I even installed new fuel injectors with no luck. So I am wondering if the MAP sensor can act like this when it goes out?
-I tried reading the codes after changing the fuel injectors and what I got was constant blinking check engine light, which I don't believe means anything. Then I disconected the Map sensor and hooked it back up and tried to start the vehicle with no luck and did the code reading one more time. This time I got a 31 which I believe is related to the MAP sensor, now I don't know if I got the code because I had just disconnected it and hooked it back up or if it is the problem???? ANy thoughts.... -Also they are very expensive so I was hoping to pick up a test sensor or two out of a junkyard, now I need to know what years and models of vehicles Toyota made that would have this same sensor? I know I won't find any 94 celicas in our junkyard, maybe a few of there trucks?????? THanks guys |
bdog_v MAP sensor? Aug 3, 2007 - 7:57 PM
Bitter a camry of the same years should have the correct ... Aug 3, 2007 - 11:39 PM
Dragondog http://www.6gc.net/forums/index.php?showto...50654... Aug 4, 2007 - 5:31 AM
Gary Yes, if you disconnect the MAP sensor and try to s... Aug 4, 2007 - 11:57 AM
bdog_v Well I tried another MAP sensor it still didn... Aug 4, 2007 - 5:35 PM
toyotacrazy QUOTE(bdog_v @ Aug 4, 2007 - 5:35 PM... Aug 5, 2007 - 5:18 PM
Dragondog http://www.6gc.net/forums/index.php?showtopic=5065... Aug 4, 2007 - 10:20 PM
6strngs ^^ wow dude, calm down a little.
anyway, as I sai... Aug 4, 2007 - 10:56 PM
Dragondog QUOTE^^ wow dude, calm down a little.
my bad sry... Aug 5, 2007 - 5:11 AM
bdog_v THanks for the apology, I started a new post as I ... Aug 5, 2007 - 2:39 PM
Dragondog i respect that you did not get mad at me kinda ma... Aug 5, 2007 - 3:06 PM
bdog_v Well guys I just got home from working over the ro... Aug 31, 2007 - 6:59 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 18th, 2026 - 5:12 PM |
