Aug 5, 2007 - 2:30 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
My headlights won't turn on. The last few weeks they have been sketchy, ie I need to flick the switch on and off a few times before they fire up, or either the left/right light will come on, but not both of them at the same time.
I seem to notice it happening more often when it rains, but somehow I think it is just a coincedince. I'm guessing its a wiring problem, but I don't know what it could be, as it affects both the left and right lights. It used to work by switching on/off a few times, so all the wires should be hooked up correctly. |
6gsillyca Culpable's HID system Aug 5, 2007 - 2:30 AM
Culpable04 it happened to me a few weeks ago, then my battery... Aug 6, 2007 - 6:52 AM
AudioFreak Don't flick HID's on and off. It puts a hu... Aug 6, 2007 - 12:14 PM
6gsillyca I will try and check my alt. Would it be better to... Aug 8, 2007 - 12:02 AM
Coomer How are they wired currently? You're using a r... Aug 6, 2007 - 2:26 PM
chacha every time it rains...especially hard, i don't... Aug 7, 2007 - 12:53 AM
Coomer I'd definitely wire them using a relay. You ru... Aug 8, 2007 - 4:11 AM
6gsillyca QUOTE(Coomer @ Aug 8, 2007 - 3:11 AM... Aug 8, 2007 - 11:01 AM
Coomer QUOTE(6gsillyca @ Aug 8, 2007 - 9:01... Aug 10, 2007 - 12:48 PM
6gsillyca QUOTE(Coomer @ Aug 10, 2007 - 11:48 ... Aug 11, 2007 - 12:06 PM
Coomer QUOTE(6gsillyca @ Aug 11, 2007 - 10... Aug 11, 2007 - 5:13 PM
6gsillyca QUOTE(Coomer @ Aug 11, 2007 - 4:13 P... Aug 12, 2007 - 12:57 AM
iparadox Any suggestions on a source to get a relay kit / w... Aug 8, 2007 - 5:37 PM
Culpable04 QUOTE(iparadox @ Aug 8, 2007 - 5:37 ... Aug 8, 2007 - 5:42 PM
6gsillyca Quick question.
Before I used to be able to turn ... Aug 9, 2007 - 10:59 PM
iparadox Should we be using a diode to prevent voltage spik... Aug 13, 2007 - 12:59 PM
Culpable04 QUOTE(6gsillyca @ Aug 12, 2007 - 12... Aug 13, 2007 - 2:47 PM
6gsillyca Well I went to the parts store today, and picked u... Aug 13, 2007 - 10:46 PM
6gsillyca just came back inside after playing around with wi... Aug 14, 2007 - 3:41 AM
Culpable04 no they are not connected, they act independent. Aug 14, 2007 - 5:40 AM
6gsillyca So me thinks its either both of the bulbs or both ... Aug 14, 2007 - 11:17 AM
6gsillyca Found the problem. It was in the wiring. Stupid th... Aug 16, 2007 - 2:41 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 31st, 2026 - 12:12 PM |
