> 3sgte swap compared to ...
post Aug 5, 2007 - 10:02 PM
a lot of people often ask what you can compare the performance of a swapped celica with bolt on mods to. after some careful research, i think our rival would be the stage2 sti. stage 2 on the sti consists of exhaust, boost controler at 19psi, and an ecu tune. this gives the sti about 300hp 340tq at the wheels. on the "street" this car would be dead even with a 3sgte swap with bolt on mods, at 15psi.
post Aug 6, 2007 - 12:59 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
post Aug 6, 2007 - 1:53 AM
yeah, no doubt about that. these cars run high 12s/low 13s in the 1/4. while ours do much worse from a dig, simply due to traction limitations of fwd.
but, 90% of peoples enjoyment of the car is from a roll. so, the original post still counts as a good example of how you can expect the car to perform on the street.
post Aug 6, 2007 - 8:18 AM
street racing isn't condoned on this board.....nor is discussion of such
post Aug 6, 2007 - 9:27 AM
Redline08
Joined Feb 23, '07
From Albany, NY
its not condoned so when u talk about it just say "track" not "street"
same concept...
post Aug 6, 2007 - 9:32 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(playr158 @ Aug 6, 2007 - 2:18 PM) [snapback]585711[/snapback]
I don't see any discussion of street racing in this thread. Discussion of street performance of our cars, but not street racing.
post Aug 6, 2007 - 9:37 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Wow. I can't be sure, but I think Lagos just said "stage 2". Someone's been playing too much Gran Turismo biggrin.gif
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Aug 6, 2007 - 9:42 AM
QUOTE(playr158 @ Aug 6, 2007 - 9:18 AM) [snapback]585711[/snapback]
thank you for doing such a good job at moderating the threads. now move along, because thats not what this topic is about.
post Aug 6, 2007 - 10:44 AM
personnally i think you might do well against a mildy (chip only) jetta 1.8t
considering i ran the same times as P2 and Def did on my non-chipped 1.8t
(14.3 area +/- .2) those are times i saw them run @ the last meet we were at
granted Jeff has hit ~13.9s a chipped jetta is there if not slightly faster
This post has been edited by playr158: Aug 6, 2007 - 10:45 AM
post Aug 6, 2007 - 11:00 AM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
i have actually went up against a wrx a r32 vw and a 04 mustang gt and beat em from a dig. Just learn how to launch your car correctly and the celica is good to go. I am going to the track on thurs and i will post time slips up when i get back.
post Aug 6, 2007 - 11:11 AM
QUOTE(playr158 @ Aug 6, 2007 - 11:44 AM) [snapback]585731[/snapback]
what was your mph?
joel (5th guy from ctech) ran a 13.8 on his swap, and i think clayton (5th gen) claims to have done a 13.6. ill try to see if i can dig up any slips from those guys.
This post has been edited by lagos: Aug 6, 2007 - 11:14 AM
post Aug 6, 2007 - 11:30 AM
What do they have done on their swaps?
6gc vs 5gc weight?
this is an AVERAGE time slip for MY jetta
specifications
tyres: GOODYEAR Eagle LS (standard touring all-season)
http://www.goodyeartires.com/goodyeartires...mp;sidewall=B01
run @ 22psi air pressure
motor: Forge MBC set for 18psi, 4 bar FPR (up from 3 bar), NON-chipped, oem exhaust
give me a set of BFG drag radials and I would have seen 14.0
i found joels info...
R/T .125
60' 2.055
330 5.835
1/8 8.931
MPH 79.36
1000' 11.629
1/4 13.880
MPH 100.14
link to video of run
http://www.celicatech.com/gallery/misc.php...file&i=7175
i think his car only dynoed at 200hp.
clayton claims 13.6 at 103mph. on the stock downpipe, with a 2.5in crush bent exhaust as his best time ever. but i was not able to find a time slip.
post Aug 6, 2007 - 11:34 AM
thats p2 and jeff....both on MUCH better tyres then the jetta was on.
figure take a base 1.8t 02+ jetta and put a chip on...should be nice a close!
This post has been edited by playr158: Aug 6, 2007 - 11:34 AM
post Aug 6, 2007 - 11:44 AM
here is the 1/4 of the stage2 sti.
R/T --- .838
60' --- 1.900
330 --- 5.467
1/8 --- 8.466
MPH --- 83.05
1000 ---11.024
1/4 --- 13.196
MPH --- 104.41
bare in mind that it was this drivers first time at the track.
i think what we really need to do, is compare the MPH of these cars. one car can run a more impressive 1/4, but another car, with a higher 1/4 time, could be faster from a roll. the track mph would reflect that.
This post has been edited by lagos: Aug 6, 2007 - 11:49 AM
post Aug 6, 2007 - 11:47 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
I got back from nopi, sti's are barely breaking 100mph with high 13's low 14's. it was also sweltering out, remember temps and altitude play a good role in times.
post Aug 6, 2007 - 11:56 AM
i really don't think just by looking @ the MPH from the 1/4 run you are going to be able to base claims on races from a roll..
my mph is clearly lower than an STi but i can beat one from a roll...they slow after 100mph
post Aug 6, 2007 - 11:58 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Dan, we run our cars at Island Dragway. Its a hole in the wall track thats almost never maintained. Times are slower at this track due to poor staging conditions. If you ran your Jetta there you can easily tack on a half of a second to your run.
The reason we go there, is because we can get in 9 runs in one day not 2.
I will return one day.
post Aug 6, 2007 - 12:01 PM
QUOTE(playr158 @ Aug 6, 2007 - 12:56 PM) [snapback]585749[/snapback]
but this is a stage2 sti. bone stock, it dynoed at 259hp263tq. stage2 it did 300hp 340tq. so i think the stage2 would be faster then you from a roll.
DISCLAIMER.... when i say "from a roll", i mean, how the cars perform, on their own, after they get out of 1st gear. im not talking about anything illegal.
post Aug 6, 2007 - 12:07 PM
Jeff, its just an example post up a slip of somewhere else...that has a 13.6 ?!
it really doesn't matter considering the aforementioned 13.9 ? time you ran somewhere else, no?
i really don't care why you go to a certain track.
yea i think a stage2 could get MY jetta on a roll sure, but put it against a chipped jetta and i think it would be a square race.
so the bunch of Chipped Jetta/GTI, Stage2 STi, 3sgte swapped 6gc (all with standard bolts ons, intake/exhaust) should be relatively close in conditions besides the DIG where the STi gets the AWD advantage
This post has been edited by playr158: Aug 6, 2007 - 12:58 PM
Lo-Fi Version Time is now: June 13th, 2026 - 4:40 AM
