Aug 6, 2007 - 12:29 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
hey guys i recently ran into some trouble with the celi. After driving one day my car cut out, tried cranking again, after two or three tries it eventully fired up again. I drove a little longer and it died again! once i got it home i had rough ilding and sputtering. Btw during all this there is no loss of power to the engine so we can rule out any battery problems.
Things i have done: Fuel injector cleaner Vavoline Water Remover. any ideas.... After adding the water remover the car drove fine for an hour, then i let sit and hasnt fired up since.....? I hope its just the fuel filter. This post has been edited by celica47: Aug 6, 2007 - 12:37 AM -------------------- I'am Reinventing the SLow Lane.....
Aug 6, 2007 - 8:18 PM
![]() Enthusiast ![]() ![]() Joined Dec 12, '06 From Fob Sharana, Afghanistan Currently Offline Reputation: 2 (100%) |
Engine Oil? Too much oil can cause those symptoms. Just a quick guess. Also check the distributor and valves psi.
This post has been edited by FortuneCookie: Aug 6, 2007 - 8:20 PM |
Aug 6, 2007 - 9:31 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Yeah, are you getting spark to all cylinders? Check that.
Aug 6, 2007 - 10:57 PM
Eh nah i doubt its the engine oil. Question, if my car wasnt firing on all cylinders why would it crank sometimes and drive for awhile?
Aug 8, 2007 - 2:31 PM
Update: got the car to the shop mechanic tells me injectors are not getting signal but they are working.... Does they make any sense?
Aug 8, 2007 - 3:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
mine did this a while back, i had a full tune-up and it was perfect after
| Lo-Fi Version | Time is now: May 19th, 2026 - 1:33 PM |
