> power steering belt help, asap please! :)
post Aug 9, 2007 - 1:49 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
so im changing my power steering belt because my old one broke and i cannot find the correct bolts to loosen the power steering pulley to slide on the belt. i got the alternator one loose but how am i supposed to go about putting on the P/S belt?
(i looked through 5 pages of searching but i have to be at work somewhat soon... 17 pages is too much)
some help would rock!
post Aug 11, 2007 - 6:22 AM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
i changed my camblet myself a month ago an im not too into cars so i didnt take too much notice, but from memory
the power strearing belt is behind the timing belt correct?
that will make it a mission as the cambelt will need to be cut
but the whole power stearing pully assembly at the rear end of the car (the wheel ASSEMBLY) gets loosened by a single bolt and should forward. The bolt is to the right of the pully i think, it took me a little bit to find but if you look carefully and not fustrated youll see what bolt it is but just studing the parts. there is a marking on the block or wall so that you put it back in the right place. this loosens the tension so the new belt can be fitted and then re-tensioned
This post has been edited by beno: Aug 11, 2007 - 6:31 AM
Lo-Fi Version Time is now: June 28th, 2026 - 5:09 PM
