> 2nd gen vs 3rd gen flywheel...... i assume they are the same right?, i jsut decided to change the title since the question was diffrent....
post Aug 9, 2007 - 2:57 PM
urbandork
Joined Jul 16, '04
From Los Angeles
Im pretty sure the answer is yes but i figured id ask anyway....
..... the 2nd gen 3sgte flywheel is the same as the 3rd gen 3sgte flywheel right??? weight and everything else???
I need a new flywheel and thus have given light weight ones a thought. First off how heavy are the stock ones? and how light is to light? I mostly do aggressive street driving as well as a little bit of canyon running.
Also what companies are out there for us and which kind of metal should i be looking for?
thanks
This post has been edited by urbandork: Aug 10, 2007 - 2:45 AM
post Aug 9, 2007 - 10:38 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I weighed the stock flywheel on a home scale a few years back. It weighed 15lbs.
I installed a 10lbs. Fidanza flywheel, I dont know the difference between the two. I never had the stock flywheel.
I will return one day.
post Aug 10, 2007 - 1:44 AM
urbandork
Joined Jul 16, '04
From Los Angeles
opps
This post has been edited by urbandork: Aug 10, 2007 - 3:39 AM
post Aug 10, 2007 - 3:40 AM
urbandork
Joined Jul 16, '04
From Los Angeles
im pretty sure they are the same... i hope
post Aug 10, 2007 - 12:16 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(urbandork @ Aug 10, 2007 - 1:40 AM) [snapback]586880[/snapback]
They are *almost* the same. The teeth for the starter are slightly different between the two, but everything else works. I have an aluminum 2nd gen Fidanza on my 3rd gen with the 3rd gen starter and it makes a slight noise when releasing the starter. Otherwise, everything is fine. smile.gif
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: August 4th, 2026 - 12:25 PM
