Aug 10, 2007 - 3:40 AM
![]() Enthusiast ![]() Joined Sep 9, '04 From England Currently Offline Reputation: 0 (0%) |
guys,
was cleaning the engine bay sunday with the engine on tick over, and i noticed air leaking from my SARD Atmo BOV, from looking at it, the adjustment screw is all the way in...should i beable to feel air leaking from it? thanking u muchly in advance with mucho kudos on this fine and sunny day Adrian |
Aug 10, 2007 - 10:27 AM
no, it shouldnt leak at idle. probably something wrong with the valve.
Aug 10, 2007 - 10:52 AM
QUOTE(lagos @ Aug 10, 2007 - 4:27 PM) [snapback]586926[/snapback] no, it shouldnt leak at idle. probably something wrong with the valve. thanks mate, confirmed my assumptions, HKS ssqv on order tomorrow.... this car thing is getting expensive |
Aug 10, 2007 - 12:20 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
Since your car uses a speed-density system for engine control, a leaking BOV won't matter too much. That is, if the valve works correctly otherwise.
I found that I get a fair amount of compressor surge on mild throttle lifts with the HKS SSQV, so I run the stock valve for daily driving. With an intake, the stock one makes plenty of noise. When I want attention (at the drag strip, etc.), I switch over to the HKS. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:41 PM |
