Aug 14, 2007 - 12:42 AM
Enthusiast Joined Jul 29, '07 From Aruba,Curacao Currently Offline Reputation: 0 (0%) |
hi guys.. i'm from curacao ,i have a 1997 st 205 alltrac JDM celica in curacao and on aruba i have a ford lightning pickup that runs low 12 sec but soon to be a 11 sec truck ..
I am searching for an front mount intercooler kits for my st205. Well i once saw a kit for under 250 dollars at ss autochrome but i cant find it on the site anymore. Well let me know where can e buy an intercooler kit Tnx John |
Aug 14, 2007 - 11:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
1997 st205 alltrac....what is that? do you mean GT-4? (i figure this is just a regional difference on what the name is, just asking for clarity) If the car is an st205, then it has the 3rd gen 3sgte, and the car comes with a water 2 air intercooler, which is one of the better intercool systems you can go with. I see no point to (in my eyes) downgrade to an Air 2 air, unit. Why change it from Water2air, to Air2air? What are your Horsepower goals for this car? ^With this info, people can suggest kits, or atleast intercoolers to fit your want/need, and somethign that can fit your budget as well. -------------------- ![]() Kawi Love |
Aug 14, 2007 - 11:54 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
Itll be hard to find a better answer to your question than that one. Nice Miguel.
Aug 14, 2007 - 1:15 PM
Enthusiast ![]() Joined Nov 21, '05 From Quebec Currently Offline Reputation: 0 (0%) |
I use big dodge neon radiator for refresh WTA and hi-flow 12v water pump... I dont know how much HP can take against
-------------------- Celica GTS turbo 1994
3sgte genIII Ct20b |
Aug 14, 2007 - 1:16 PM
well i'm looking for 400 whp to 500 whp..
We have an gen 2 3sgte in a 1983 starlet and it has on 22 psi gt35r and 20 degrees of timing with has 410 rwhp and it runs on 90 shot of nitrous... It runs 9.6 sec in the 1/4 mile. well i'm forging my engine right now.. tnx .. |
Aug 14, 2007 - 1:29 PM
If you check out Itchy:
http://www.6gc.net/members/407 "300x600x3" Bar and Plate FMIC" I believe his Intercooler is rated for 500 to 600hp. It is not a kit, and he probally spent about $300+ for just his Intercooler. But with views as lofty as 400 and 500hp it wont be cheap. Itchy dynoed his car at ~330 Front wheel hp, with a Holset Hx35 Turbo. (larger turbo off a Dodge Ram Pick up) Also, check out: Tufy http://www.6gc.net/members/2022 He has a Gt-4 with ~610 All Wheel HP. It gives you an idea of the mods, and Money needed to obtain your goal. Final comment: I don't believe there is a "cheap" bolt on kit for our cars. Your best bet is to do some research, then seriously access your budget, and goals, to see what is obtainable. Then take your time, and piece together a kit yourself. Good Luck. Hope to see your build up in the near future. edit: spell check ftw This post has been edited by devilsden97: Aug 14, 2007 - 1:48 PM -------------------- ![]() Kawi Love |
if your looking for that much power, then you probably have a fair bit of money to spend. buy something better then budget ssautochrome crap.
Aug 14, 2007 - 2:37 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
QUOTE(devilsden97 @ Aug 14, 2007 - 2:29 PM) [snapback]587993[/snapback] Also, check out: Tufy http://www.6gc.net/members/2022 He has a Gt-4 with ~610 All Wheel HP. It gives you an idea of the mods, and Money needed to obtain your goal. Sorry for being off topic, but I thought Tufy has ~480 awhp. Is this 610 awhp on GT35? Did he post a dyno plot somewhere? -------------------- _Gary
Aug 14, 2007 - 3:52 PM
He posted one a while back, I could be mistaken.
Let me look. edit: went to the dyno charge stickies in FI. Tufy: 1994 model gt-four st 205 3sgte engine, full modified internals, power fc ecu, 272 deg cams ect.. Garrett Gt35R turbo 22.4 psi boost with pump fuel 4wd dynojet so you are correct. (i thought somewhere, it was mentioned 600awhp) This post has been edited by devilsden97: Aug 14, 2007 - 3:55 PM -------------------- ![]() Kawi Love |
Aug 14, 2007 - 3:57 PM
QUOTE(devilsden97 @ Aug 14, 2007 - 4:52 PM) [snapback]588025[/snapback] He posted one a while back, I could be mistaken. Let me look. edit: went to the dyno charge stickies in FI. Tufy: 1994 model gt-four st 205 3sgte engine, full modified internals, power fc ecu, 272 deg cams ect.. Garrett Gt35R turbo 22.4 psi boost with pump fuel 4wd dynojet so you are correct. (i thought somewhere, it was mentioned 600awhp) 480AWHP would be ~600+- at the flywheel -------------------- Former Team 5SFTE pro member ;)
Aug 14, 2007 - 10:56 PM
QUOTE(devilsden97 @ Aug 14, 2007 - 11:41 AM) [snapback]587972[/snapback] If the car is an st205, then it has the 3rd gen 3sgte, and the car comes with a water 2 air intercooler, which is one of the better intercool systems you can go with. I see no point to (in my eyes) downgrade to an Air 2 air, unit. Why change it from Water2air, to Air2air? Because the stock ST205 intercooler does not support his horsepower goals. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Aug 15, 2007 - 1:17 AM
QUOTE(jgreening @ Aug 14, 2007 - 11:56 PM) [snapback]588075[/snapback] QUOTE(devilsden97 @ Aug 14, 2007 - 11:41 AM) [snapback]587972[/snapback] If the car is an st205, then it has the 3rd gen 3sgte, and the car comes with a water 2 air intercooler, which is one of the better intercool systems you can go with. I see no point to (in my eyes) downgrade to an Air 2 air, unit. Why change it from Water2air, to Air2air? Because the stock ST205 intercooler does not support his horsepower goals. ^if u look, my statement is prior to my knowledge of his HP goals., after then i send him in the direction of parts, and upgrades. -------------------- ![]() Kawi Love |
Aug 15, 2007 - 1:53 AM
tnx for the help guys.. well i'm buying an gt35 right now... i am thinking about the the intercooler right now..the intercooler kit of ssautochrome sound nice... but i'm looking for an another options right now..
Aug 15, 2007 - 3:37 PM
QUOTE(devilsden97 @ Aug 15, 2007 - 1:17 AM) [snapback]588111[/snapback] QUOTE(jgreening @ Aug 14, 2007 - 11:56 PM) [snapback]588075[/snapback] QUOTE(devilsden97 @ Aug 14, 2007 - 11:41 AM) [snapback]587972[/snapback] If the car is an st205, then it has the 3rd gen 3sgte, and the car comes with a water 2 air intercooler, which is one of the better intercool systems you can go with. I see no point to (in my eyes) downgrade to an Air 2 air, unit. Why change it from Water2air, to Air2air? Because the stock ST205 intercooler does not support his horsepower goals. ^if u look, my statement is prior to my knowledge of his HP goals., after then i send him in the direction of parts, and upgrades. You did state that you see no point to "downgrade" to an air to air unit. Since that is an ignorant statement, I thought it might be helpful to you (and others) if I pointed out that the ST205 intercooler will not support as much horsepower as some good A/A units. Just trying to help - no biggie. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Aug 15, 2007 - 5:14 PM
but again, when i mentioned the downgrade, i was unaware of his goals. If i knew, I wouldnt have stated that the A2A is a downgrade.
Aug 15, 2007 - 7:39 PM
QUOTE(devilsden97 @ Aug 15, 2007 - 6:14 PM) [snapback]588239[/snapback] but again, when i mentioned the downgrade, i was unaware of his goals. If i knew, I wouldnt have stated that the A2A is a downgrade. christ, migga, just let it go. -------------------- Former Team 5SFTE pro member ;)
Aug 15, 2007 - 8:44 PM
i saw mention of SSautochrome intercooler....DO NOT GET IT its cheap POS
spearco is nice |
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:48 PM |
